AAA/AUTHEN (2520983360): status = ERROR
May 23rd, 2012
I am getting aaa/authen status = error  messages when I am debugging the aaa authentication.
tacacs is verymuch reachable with no request timeout.
sometimes its authenticating with TACACS.  Many times its authenticating with local.
enable password its always authenticating with local.
I am not finding any failure log in ACS.
AAA server is Cisco Secure ACS 1121 - 5.2 Version
AAA Client is Cisco 2950 Swtich.
Anyone can help?
If you can send your 2950 aaa config, it might help, but I'm guessing you need something like the following to make the switch check TACACS (ACS) first, then look local when going into priv exec:
     aaa authentication enable default group tacacs+ local
Just a guess, since I've never seen that error, but if you can show your aaa config it would help eliminate that as a problem.
--Chris
lenins.akm Wed, 05/23/2012 - 07:25
Hi Chris,
Thanks for your reply. This is my switch config.
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
tacacs-server host 10.1.7.150
tacacs-server key tatasky
line vty 0 4
transport preferred telnet
login authentication default
Your aaa authentication config looks right to me.  As I'm sure you know, according to your config, if the ACS is available, then your switch should never look locally for authentication.  (If ACS can't find a valid account, it will send back a deny message, and the switch will not allow access, regardless if the user account is present locally)  So I'm kinda stuck there.
Any chance you could 'debug aaa authentication,' login and enable, then paste a (sanitized) log results?  Otherwise, there should be log entries that say something like:
     May 23 15:45:11.888 ZULU: TAC+: (-000000000): received author response status = PASS_ADD
     May 23 15:45:11.999 ZULU: AAA/AUTHEN/LOGIN (00000000): Pick method list 'default'
The first one indicates successful communication with the ACS, and the second verifies that TELNET logins map to the default method (aaa authentication login default group tacacs+ local)
lenins.akm Wed, 05/23/2012 - 09:31
49w4d: TAC+: send AUTHEN/START packet ver=192 id=2520983360
49w4d: AAA/AUTHEN (2520983360): status = ERROR
49w4d: AAA/AUTHEN/START (2520983360): Method=LOCAL
This the error log when I am debugging.
reachability of AAA server is 10000/10000 ping requests.
AAA client is added already.
Jatin Katyal Wed, 05/23/2012 - 10:55
  • Cisco Employee,
As per debugs, seems like authentication hitting local database.
did you try from the device
telnet 49
also add this command if not configured already:
ip tacacs source-interface
In case it doesn't work the run
debug aaa authen
debug tacacs
let me know how it goes.
Jatin
