What I need to simulate a PSTN
Edip Gumuskaya
Hi All,
Working towards me CCIE Voice Lab exam.....
I have 3745 Router with:
1 x NM-HDV
3 x PVDM-12
1 x VWIC-1MFT-E1 Module.
1 x 7960 Phone
I have placed a Loopback cable in the single E1 socket, but I get "RX <- BAD FRAME" received when debug isdn q921 is turned on. So this will not help me simulate a PSTN for me to see Q931 traffic.
Would a single VWIC-2MFT-E1 card be enough to simulate a ISDN q931 and q921 message if I loop the ports together with a E1 crossover and set one as USER and the other NETWORK?
I am trying to go for least cost solution with what I already have?
Ed
You need two different routers. You are connecting them back to back. You cant do this on the same router.
You need 1 router acting as PSTN
you need another router acting as the User side
Pls rate useful posts
Please rate all useful posts
11 Replies 11
Chris Deren
No, you will need 2 ports and connect them via cross-over T1 cable as well as setup one side as ISDN protocol-emulate network.
HTH,
Chris
Hi, here are the configuration you need. As chris said you need a cross over E1 cable to connect the two routers back to back.
The pinout for a corss over e1/t1 is as follows:
1 <-> 4
2 <-> 5
4 <-> 1
5 <-> 2
Router 1 (PSTN SIDE)
controller E1 0/2/0
clock source internal (Because its PSTN side, it is the clock provider)
pri-group timeslots 1-31
description E1 Link to Labrouter 2
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn timer T310 120000
isdn protocol-emulate network (****Simulating PSTN SIDE)
isdn incoming-voice voice
no cdp enable
Router 2 (user side)
controller E1 0/1/1
description E1 Link to Lab PSTN
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp
Thanks guys,
Can I confirm that this can be done on the same route with 1 x 2 port VWIC card?
I understand that I will see both the inbound and outbound q931 messages on the same router.
Thanks guys.
I'll keep a watch out for another voice router going for cheap than,
I suppose teaching people how to fish does not go far these days and step by step instructions are much more appreciated :-(
Chris
Chris,
+5 for your inputs. I am actually confused as to how to help people on this forum. Should they be fed completely or should you lead them on the proactive approach. I mean sometimes you post a link to a document and people wont even bother reading it, so I share your thoughts...
Thanks, but you did not rate m y post :-)
Now I did..I rated the wrong post
Chris Deren
Surely you can do this on the same router, for studying it will do the job.
Edip,
Chris is right, you can do it on the same router..I got things mixed up. But you need two different ports configured as I explained int he config section
