Why some switch ports does not show mac address
May 23rd, 2012
                   Hi all,
I was finding  out which device is connected to switch port.
I did this command to find mac address
sh mac address-table int gigabitEthernet 2/23
Multicast Entries
vlan    mac address     type    ports
225    ffff.ffff.ffff   system Gi2/1,Gi2/2,Gi2/4,Gi2/5,Gi2/6,Gi2/7,Gi2/8
                                Gi2/9,Gi2/10,Gi2/11,Gi2/12,Gi2/13,Gi2/14
                                                              Gi4/39,Gi4/43,Gi4/48,Po25
625    ffff.ffff.ffff   system Gi2/1,Gi2/2,Gi2/5,Gi2/6,Gi2/7,Gi2/8,Gi2/9
                                Gi2/10,Gi2/11,Gi2/12,Gi2/14,Gi2/15,Gi2/16
                                                              Gi4/48,Po25
seems ffff is all broadcast address .
Need to know why this is not showing mac address thanks
MAhesh
Overall Rating: 5 (2 ratings)
Ivan Shirshin Wed, 05/23/2012 - 09:47
  • Cisco Employee,
Hi Mahesh,
What are the switch model and IOS version?
Kind Regards,
Ivan
**Please grade this post if you find it useful.
mahesh18 Wed, 05/23/2012 - 10:28
Hi Ivan
cisco WS-C4506  and
bootflash:cat4500-ipbasek9-mz.122-54.SG.bin"
Ivan Shirshin Wed, 05/23/2012 - 11:05
  • Cisco Employee,
Hi Mahesh,
Check if you have broadcast storm in the network. Also verify for STP transitions:
    show span int gi2/23  //check for topology changes
I saw similar issue related to static mac configuration. Do you have any of that in the config?
Kind Regards,
Ivan
mahesh18 Wed, 05/23/2012 - 11:30
Here is info
sh spanning-tree int gi2/23
Vlan                Role Sts Cost      Prio.Nbr Type
VLAN0225            Desg FWD 3100      128.87   P2p Edge
VLAN0625            Desg FWD 3100      128.87   P2p Edge
I chekced no static mac on switch port config.
thanks
mahesh
Correct Answer
Giuseppe Larosa Wed, 05/23/2012 - 14:33
  • Hall of Fame,
    Founding Member
Hello Mahesh,
L2 information for the port looks like fine.
To learn a MAC address on the port the attached device has to speak and to be understood by the switch port.
So a first possible case is given by some incompatibility between more modern C4500 linecards  (I remember a case with WS-4648 on new C4500 that required upgrade of network drivers on PC NICs)
Another possible situation is given by wake on lan the connected device is powered but it does not show activity so no MAC is learned on the port.
CAM aging time is by default only 300 seconds so another case is a device like a PC that is powered on, connected but it hasn't used the LAN for more then 300 seconds so its entry has expired and it has been removed from CAM table
Hope to help
Giuseppe
mahesh18 Thu, 05/24/2012 - 19:59
Hi Giuseppe,
Thanks again seems its some wake on lan setup on main switch.
MAhesh
rizwanr74 Wed, 05/23/2012 - 11:53
  • Gold, 750 points or more
"Why some switch ports does not show mac address"
Because those port in question in a vlan, for which have layer2 definition yet to be created.
meaning you assigned a port to a vlan but you have not created a layer2 defenition.
Hope that answers your question.
thanks
mahesh18 Wed, 05/23/2012 - 11:59
Thanks for reply.
I check port config it is assigned to Voice and data vlan.
Can you please explain below
thanks
MAhesh
Reza Sharifi Wed, 05/23/2012 - 14:41
  • Cisco Designated VIP,
    2017 LAN
Mahesh,
In addition to the options provided by Giuseppe (Hi Giuseppe, long time no see) try pinging the device and than issue the sh mac address-table command.
This usually does not apply to PC, Laptop, etc.... but I have seen some video camera encoders that the MAC address does not show up on the switch unless you ping it first.  Strange right?
mahesh18 Wed, 05/23/2012 - 15:52
Hi Reza,
Sh ip arp does not work also i do not know IP address of device.
MAhesh
Reza Sharifi Wed, 05/23/2012 - 16:01
    2017 LAN
Hi Mahesh,
Try clearing the MAC table:
clear mac address-table dynamic interface gi2/23
and than try "sh mac address-table again
redlawpy05 Fri, 07/25/2014 - 05:52
This really helped me, thanks! I had trouble with a similar device.
The switch didn't cached the mac address of the device. So I just pinged the device :)
I think you could ping to the broadcast if you don't know the exact address.
Leo Laohoo Wed, 05/23/2012 - 15:00
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Most of the time, the MAC address does not show up when the clients have logged off.  This is very common nowadays with PCs.  Another is when a server's dual NIC isn't configured properly for "teaming".
If you don't know the exact IP address, there's an old trick (not foolproof) you could try.  IF you know what VLAN the NIC is in, ping the broadcast IP address from the switch.  Sometimes it just may work.
mahesh18 Wed, 05/23/2012 - 15:51
Hi leolaohoo,
The port is up up.
I know port is in voice and data vlan.
How can i find the broadcast IP for each vlan?
MAhesh
Leo Laohoo Wed, 05/23/2012 - 16:59
  • Hall of Fame,
    2017 LAN, Wireless
Please post the output to the command:  sh interface VLAN .
mahesh18 Wed, 05/23/2012 - 17:32
Hi leolaohoo,
Here is info
  Internet address is 192.168.20.1/24
MAhesh
Leo Laohoo Wed, 05/23/2012 - 18:37
  • Hall of Fame,
    2017 LAN, Wireless
Your broadcast IP address is 192.168.20.255.  Ping that.
mahesh18 Wed, 05/23/2012 - 20:36
Hi leolaohoo,
If i ping to broadcast IP  my concern is that will this increase cpu spike as it is production device?
When i ping this IP it will send ping to all devices connected to this Vlan right?
also to other nei switches which are in data vlan right?
Mahesh
Leo Laohoo Wed, 05/23/2012 - 20:43
  • Hall of Fame,
    2017 LAN, Wireless
Ping won't kill CPU.
If your switches are all in the same subnet, yes.
mahesh18 Thu, 05/24/2012 - 07:49
Hi Leolaohoo,
My bad the switch function as layer 2 it has static default route to core device.
Data vlan is on core switch.
IT has runk connection to core switch.
MAhesh
