Warning message
Rate policing
Answered Question
May 23rd, 2012
we have two departments each department is in it's own subnet. Config as follows:
class-map match-any RTLMT-Dept
match access-group name Dept1
match access-group name Dept2
policy-map RATE-LIMIT
class RTLMT-Dept
   police 6000000 1125000 2250000
     conform-action transmit
     exceed-action drop
     violate-action drop
interface GigabitEthernet0/0
ip address 10.0.0.1 255.255.255.252
duplex auto
speed auto
no cdp enable
service-policy input RATE-LIMIT
ip access-list extended Dept1
permit ip any 10.1.0.0 0.0.0.255
ip access-list extended Dept2
permit ip any 10.2.0.0 0.0.0.255
Total internet speed provided by ISP is 12 Mbps.
So will these Depts share 6 Mbps or every Dept will have their speed of 6 Mbps?
Thanks.
Correct Answer by Sergey Fer about 5 years 2 months ago
Their joined incoming traffic will be restricted up to 6 Mbps. For every Dept to have it's own 6M you need to create two classes and police each class.
Overall Rating: 5 (1 ratings)
Correct Answer
Sergey Fer Wed, 05/23/2012 - 11:25
  • Bronze, 100 points or more
Safar Safarov Sat, 08/18/2012 - 03:57
Sergey,
in case of having more than 100 Depts any easy way to accomlish the task?
Joseph W. Doherty Sat, 08/18/2012 - 04:28
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Safar Safarov wrote:
Sergey,
Depends on your underlying requirements, but some switches, like the 6500, support (micro) flow or user (ubrl) policing.
Safar Safarov Sat, 08/18/2012 - 10:50
Joseph,
Let's say, I have 100 Mbps ingress internet traffic to my router and I would like to police it among 100 users limiting each user to 1 Mbps. But creation of 100 classes to accomplish that seems to me a little bit strange. Therefore I'm looking for a way how to do that with the less administrative effort.
BR,
Safar.
Joseph W. Doherty Sat, 08/18/2012 - 17:57
Disclaimer
Posting
That's the major feature of per flow or per user policing, you don't define and manage 100 classes.  You apply a special policer on an aggregate path that's able to distinguish and enforce policing per flow or per user.
Did you search for micro-flow and/or ubrl policing on Cisco's main web site?
Safar Safarov Sun, 08/19/2012 - 03:11
Yes I found some articles, all with reference to Cisco® Catalyst® 6500/Cisco 7600 Series Supervisor Engine 720. It seems to me there is no way to apply it on Cisco 2900/3900 Series ISR...
Joseph W. Doherty Sun, 08/19/2012 - 04:03
Disclaimer
Posting
Correct, which is why I initially noted "some switches, like the 6500".  Feature is unavailable, I believe, on any ISR.
If your platform is an ISR, then you're stuck with using a large number of classes, or depending on what you really need to accomplish, perhaps a different approach to manage congestion.
Safar Safarov Sun, 08/19/2012 - 04:07
Yes I see. Would it be the same in the case if I purchase ASR instead of ISR?
Joseph W. Doherty Sun, 08/19/2012 - 04:51
Aug 18, 2012 7:28 AM                             (in response to Safar Safarov)
Rate policing
Disclaimer
Posting
Not sure as I haven't worked QoS on those and they run IOS XE.  I suspect they don't, but don't quote me.
Safar Safarov Sun, 08/19/2012 - 10:40
Okay. Then I think will go for 7600 Series.
Thanks for your help.
