Warning message
Cisco 881G - SMS commands missing
May 23rd, 2012
today I received a Cisco Router 881G with PCEX-3G-HSPA-G for a customer that ordered a Router with the feature to send/receive SMS and to remotely active the 3G Internet connection through SMS. I believe that the router that meets this requirement is the Router 881G that I received today. In particular, the model is:
CISCO881G-K9
Now, I installed the router and configured the 3G link that is working properly BUT all the commands related to the SMS are completely missing. In particular, I miss the command:
cellular gsm sms send
gsm sms archive path
In the following documentation I see that these commands should be available:
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html
The fact that these commands are missing sounds very strange to me since the documentation is pretty clear. Do I need to activate any license? I also upgraded tha router to the last version...
Here it is the show version of the Router:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.2(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 24-Mar-12 00:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
******* uptime is 1 minute
System returned to ROM by reload at 16:14:44 MET Wed May 23 2012
System image file is "flash:c880data-universalk9-mz.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 881G (MPC8300) processor (revision 1.0) with 236544K/25600K bytes of memory.
Processor board ID FCZ1607C4AQ
5 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
1 Cellular interface
256K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Any advice? Thank you very much.
awrutherford Tue, 01/08/2013 - 22:00
I think you'll find that the page you refer to says it's first introduced in 15.1(3)T, and you've got a mainline (M) release instead of a new Technology (T) release - I'd try switching to a T release and see if it's there.
