Routing and loadbalancing part 3
May 24th, 2012
Hi All
Still cant get the basic loadbalancing functon to work for some reason .- even when i do the 'sho service-policy CLIENT-VIPS' detail its not incrementing.
Dont know why but its just not working -
Also should i be able to connect to the other vlan 122 from a vlan 121 on the client side - i cant see anything in the manual about enabling routing
So any ideas anyone as i cant seem to get this to work - heres the non admin context config -
access-list EVERYONE line 8 extended permit tcp any any
access-list INBOUND line 1 extended permit tcp host 10.14.253.4 any
rserver host TEST-1
  ip address xx.xx.122.200
  inservice
rserver host TEST-2
  ip address xx.xx.122.201
  inservice
rserver host TEST-3
  ip address xx.xx.122.3
  inservice
serverfarm host TESTFARM
  rserver TEST-1
    inservice
  rserver TEST-2
    inservice
class-map type management match-any REMOTE-ACCESS
  2 match protocol icmp any
  3 match protocol telnet any
  4 match protocol ssh any
  5 match protocol https any
  6 match protocol http any
  7 match protocol xml-https any
class-map match-all VIP-150
  2 match virtual-address xx.xx.121.150 any
policy-map type management first-match MGMT_TEST
  class REMOTE-ACCESS
    permit
policy-map type loadbalance first-match lb-logic
  class class-default
    serverfarm TESTFARM
policy-map multi-match CLIENT-VIPS
  class VIP-150
    loadbalance vip inservice
    loadbalance policy lb-logic
interface vlan 121
  description Clients
  ip address xx.xx.121.10 255.255.255.0
  access-group input EVERYONE
  service-policy input CLIENT-VIPS
  service-policy input MGMT_TEST
  no shutdown
interface vlan 122
  description Servers Vlan
  ip address xx.xx.122.10 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 xx.xx.121.1
xx.xx.121.1 is the switch off which i have the client xx.xx.121.4
This is my admin context -
interface gigabitEthernet 1/1
  switchport trunk allowed vlan 121
  no shutdown
interface gigabitEthernet 1/2
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/3
  switchport trunk allowed vlan 122
  no shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ALL line 8 extended permit ip any any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
O  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 121
  ip address xx.xx.121.171 255.255.255.0
  access-group input ALLly
  service-policy input remote_mgmt_allow_policy
  no shutdown
interface vlan 122
  ip address xx.xx.122.171 255.255.255.0
  no shutdown
interface vlan 1000
  ip address xx.xx.253.20 255.255.255.0
  no shutdown
context Testing-11
  description Testing Context
  allocate-interface vlan 121-122
  allocate-interface vlan 1000
All the interfaces are up - except vlan 1000 which is not used.
Couple of (probably obvious) questions -
1. Do i need to create the 122 Server vlan in the admin context - i have assumed you must so you can allocate them to the other contexts.
2. On the physical interfaces - if you use a vlan in one you cant use it in another- do they automatically trunk ?
Currently i can ping from my client pc to the context vlan on the same vlan = xx.xx.121.10
I am using the manual from the course but it was done on a virtual appliance so i didnt really see much of the admin contexts
Maurice thanks for your help so far and if you can see anything wrong let me know.
Steve
steve switzer Wed, 05/30/2012 - 03:05
Sorry Marcel ;-)
Using some free webservers have managed to get the load balancing working to two of the servers.
However the third one is not loadbalanced and i cant seem to route to it
Any idea how i can do this -
ie -
Have 2 servers in a server farm loadbalancing
and another you just route to
Thanks for your help
Steve
Trending Topics: Other DC Subjects
