log any configuration command
Richard Burts Thu, 05/24/2012 - 09:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You can configure AAA accounting to send accounting records to report commands that users have entered and then can store the records and can report on the records from your AAA server. I have done this quite often using TACACS and it works pretty well. The configuration statement might look something like this
aaa accounting commands 15 default start-stop group tacacs+
Rick
