Pnexp command on MARS
Answered Question
May 24th, 2012
Hi guys
I got a question about a step that I need to do before I upgrade the MARS (I'm going to upgrade from 6.0.8 to 6.1.5)
•          Step 2 - Run the “pnexp” command to prepare & export a backup to an NFS or SFTP remote server.  You can export just the MARS config, just data, or both.  See below for link to syntax help.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/command/reference/cref1.html#wp1137699
As I understand I need to run this command (pnexp) to made a backup of the MARS so that's mean that after the upgrade I'm going to lose all the configuration that I had before or it's just to prevent in case that something goes wrong and maybe I need to made a re-image of the device.
Correct Answer by Jennifer Halim about 5 years 1 month ago
It is just for backup in case the upgrade didn't go smoothly and you have to roll back to this current version.
If the upgrade is successful, all your data and configuration will remain as is.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Thu, 05/24/2012 - 22:57
  • Cisco Employee,
Related Content
