connectivity between devices in mesh
Answered Question
May 24th, 2012
What is the ideal way to check connectivity & wireless strength between mesh devices like root acces point and maps, work group bridges.
this is to verify if the devices are able to transmit optimally in case there is any hard obstructing surfaces or sight problems.
Please suggest.
Thanks .
Correct Answer by Amjad Abdullah about 5 years 2 months ago
If you have WCS you can use it. You can check mesh links health.
From WCS go to Monitor->Access Points. then click on your AP name then click on your AP radio type.
see the image below.
If you don't have WCS it will be harder. You can ssh to the AP and issue some commands like:
- show mesh adjacency all.
- show mesh status.
Amjad
Overall Rating: 5 (1 ratings)
Correct Answer
Amjad Abdullah Mon, 05/28/2012 - 00:26
  • Red, 2250 points or more
- show mesh status.
Amjad
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
