4948 2x10G Etherchannel
Answered Question
May 25th, 2012
I would just like to confirm if it is possible to create a 2x10G etherchannel on a 4948.
Correct Answer by Giuseppe Larosa about 4 years 11 months ago
Hello Gerald,
yes it is possible I have seen several C4948 connected wih 2 X10GE etherchannel to a pair of Nexus 7010.
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Fri, 05/25/2012 - 01:21
  • Hall of Fame,
    Founding Member
Hello Gerald,
Hope to help
Giuseppe
gerald.suiza Fri, 05/25/2012 - 01:24
hi,
Thanks for the fast reply..would you know if there is any additional config or is it just the normal etherchannel config for 10G?
Giuseppe Larosa Fri, 05/25/2012 - 01:33
  • Hall of Fame,
    Founding Member
Hello Gerald,
standard configuration I recommend to use LACP: it is standards based and allows for detection of errors in cabling.
Hope to help
Giuseppe
Related Content
