VSS on 6509/SUP2T - big problems getting it to work
May 25th, 2012
Hi there,
I've got big problems setting up a VSS with 2 6509-E with ONE sup2T in each 6509.
I started configuring the 2 SUPs like this:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1055688
VSS config in general is not very complex.
VSL is up (2x10Gig channel from the 2 sup-ports to the 2 sup-ports)
I connected 2 4509E with sup7e with 2 links (1 to sup2t-switch1 and one to sup2t-switch2)
I used port 1 and 3 at the sup7e (i also tried other ones... 1 port on sup7e on on 4712-card... 2 on 4712 card...)
configured PagP on both sides. I had also a look to
http://www.cisco.com/en/US/products/ps9336/products_tech_note09186a0080a7c837.shtml
I started with 15.0-1 SY1 advipservices - and had problems with the PagP channels.
only the port to the active sup2T is aggregated to the channel - the second
port toggled between stand-alone and waiting to be aggregated.
I tested a lot of things.. changed ports.. cables.. SFP+'s.. X2's... rebooted.. powercycled...
than I installed 12.2.50 SY1 and everything seems to be working... at first....
I did some test - played around with some failure-scenarios - and channels broke up again.
at the moment I'm NOT able to get the channels working..
Than I configured an IPaddress in vlan 1.
the 2 4500s also have management IP in vlan1.
I was NOT able to ping the VSS..
i did a "redundancy force-switchover" and - voila - ping is working.. (I did a lot of pinging - not only one...)
switching back to switch 1 - ping keeps working....
is there anybody out there who can help me?
Is VSS on sup2t so buggy that it is not usable? I can't believe that.. ok. it's just ED..
pleeease help...
many thanks in advance
Christian
CC[NID]P
Reza Sharifi Fri, 05/25/2012 - 07:52
Hi Christian,
Can you post a quick diagram of your network showing the physical links interconnects and the Portchannels you are using?
Christian Bauer Fri, 05/25/2012 - 08:13
quick and dirty ;-)
4500s uses ports on SUP
6500 uses ports on linecard 6908
VSL via ports on SUP2t
Reza Sharifi Fri, 05/25/2012 - 08:44
What test are you performing? Are the hosts connected to the 4500 switches and pinging 6500?
Are you using ePAGP for dual-active detection of fast hello?
Christian Bauer Sat, 05/26/2012 - 01:10
Just pinging from 4500 to 6500. Both VLAN1. L2-Trunks between 45 and 65.
I'm using ePAgP. ePAgP is supported on 4500 (XE 3.3.0)
Christian Bauer Fri, 05/25/2012 - 08:24
Hello Sajid,
I tired a lot of things.. this is the current layout.
please see my other posting - I tried a lot of combinations of ports.
I changed nearly everything - SFPs/X2s/Cables/......
Christian Bauer Fri, 05/25/2012 - 08:26
SUP7e is able to handle all 4 Ports non-blocking in single SUP mode...
only while using redundancy you can only use port 1 and 2.
sajid_m123 Fri, 05/25/2012 - 08:11
Please post the diagram . Meanwhile, make sure you are following the link below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/01xo/configuration/guide/sw_int.html
Limitation and Restrictions on Supervisor Engine 7-E:
Please note the following:
When you use WS-X45-SUP7-E in RPR or SSO mode, only the first two uplinks on each supervisor engine are available. The second two uplinks are unavailable.
Christian Bauer Fri, 05/25/2012 - 08:23
SUP-7E is standalone - one SUP in one Chassis - no redundancy.
I also tried channeling one SUP port (5/1) and one port from 4712-linecard.
next try was both ports on 4712.
always the same.
I also took an 2960 and linked it up to one gigE port on each SUP2T with PagP - same problem..
link to standby-sup is always crazy.
at the moment I can't ping the VLAN1 IP of VSS-system (all switches have a management IP in VLAN1 (/24-network))
If I do a "redundancy force-switchover" the connectivity is immediatly established.. and VLAN1 of VSS is pingable.
Very strange. what hardware tests can I do to be sure that the SUPs are working well?
I also tested links with UDLD. the links to the passive chassis ALWAYS run into err-disabled.
(udld enable - not udld aggressive)
Christian Bauer Sat, 05/26/2012 - 01:06
of course - but unfortunately not before tuesday. Monday is a public holiday in Germany and I'm not in the office at the weekend.
sajid_m123 Sat, 05/26/2012 - 07:42
what is the o/p for the following;
sh switch virtual
sh switch virtual role
remote command standby-rp show switch virtual role
sh switch virtual redundancy
sh switch virtual link detail
Christian Bauer Tue, 05/29/2012 - 13:57
Hi sajid,
I think the config and VSS setup should be ok. Since today one of the 2 SUPs seems to be completly broken.
The system won't come up and crashes during minimal bootup-GOLD-Test.
I checked the plain SUP without any modules. Flash is ok. Chassis is ok.
Unfortunately SmartNet is still in progress - but I think it will be ready tomorrow and I will open a TAC Case.
I will keep you informed how things are going on.
Many thanks for your help so far,
Christian
Christian Bauer Tue, 06/05/2012 - 01:51
Hello @ll,
I got a new SUP2T on Thursday - and voila... everything is working fine now.
But anyway - thanks for your help and troubleshooting.
Greetings,
Christian
