Warning message
Cisco 878 - Transparent Bridging
May 23rd, 2012
                   Hello everybody,
I have got two 878 integrated services routers and I need to configure them as transparent bridges in order to connect 2 remote sites over ATM.
As I'm testing the topology, I configured two switches (representing the sites) at each end with a VTP domain. VTP works while the switches are connected directly with eachother, but it won't work with the bridges in the middle.
Has anyone had a similar issue before?
The configuration is identical on both routers, as follows:
Current configuration : 1228 bytes
version 12.4
no service pad
hostname XXXXXX
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
no ipv6 cef
vtp domain IE
vtp mode transparent
archive
log config
  hidekeys
controller DSL 0
mode atm
line-rate 2048
vlan 10
vlan 1002
ring 0
vlan 1003
parent 0
vlan 1004
bridge 0
stp type ieee
interface BRI0
no ip address
encapsulation hdlc
no ip route-cache
shutdown
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5snap
bridge-group 1
interface FastEthernet0
switchport mode trunk
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(24)T7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 28-Feb-12 14:33 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Client uptime is 3 hours, 57 minutes
System returned to ROM by reload
System image file is "flash:c870-advipservicesk9-mz.124-24.T7.bin"
Last reload reason: Reload Command
version 12.4
no service pad
hostname XXXXXX
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
no ip routing
no ip cef
no ipv6 cef
vtp domain IE
archive
log config
  hidekeys
controller DSL 0
mode atm
line-rate 2048
vlan 10
vlan 1002
ring 0
vlan 1003
parent 0
vlan 1004
bridge 0
stp type ieee
interface BRI0
no ip address
encapsulation hdlc
no ip route-cache
shutdown
interface ATM0
no ip address
no ip route-cache
pvc 8/35
bridge-group 1
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
The ATM interfaces are up.
show version (partial):
Everything seems to be fine except for the VTP cannot reach the vtp client switch..
Overall Rating: 2.5 (2 ratings)
Richard Burts Sat, 05/26/2012 - 19:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
I have examined the configs that you have posted. And from a bridging perspective I believe that they are fine.
Perhaps I am not correctly understanding your question. You say that the VTP cannot reach the vtp client switch. And I do not understand this since both switches seem to configure the VTP mode as transparent. So in this mode there is not a client switch.
Perhaps you can clarify the issue so that I understand it better?
Rick
Konstantinos Le... Sun, 05/27/2012 - 12:36
Thank you for your response, Rick!!
Rick
You 're right. I must clarify that the switches I'm using are two separate 3560 devices (apart from the two 878 routers). The configs of these switches are not included in the post...
However, I can assure you that the VTP client-server settings are correct, since I've tested the switches directly connected to eachother and the VTP works just fine.
Thanks again,
               Kostas.
P.S: The VTP settings that do appear in the posted configuration are only the settings of the internal switch of the 878 router.
paolo bevilacqua Sun, 05/27/2012 - 13:26
  • Hall of Fame,
    Founding Member
Why bridging? Use routing and you will have all the advantages, and none of the trouble.
Konstantinos Le... Mon, 05/28/2012 - 00:19
That was my exact reaction when my client client asked me to do this!!
Probably, he has to deal with IP range restrictions... To be honest I don't know exactly the reason my client wants to waste two 878 routers by using them as bridges.
I must also say that I had recently upgraded the IOS software of the routers, before I posted the question here.
Is there any possibility that these 878 routers are just not healthy? I've already tried different ATM encapsulation with no luck..
paolo bevilacqua Mon, 05/28/2012 - 01:38
  • Hall of Fame,
    Founding Member
To better help you customer, you should try to understand why he thinks he needs bridging, and help him remove the need by renumbering, fixing network, etc,
Even if you can get bridging to work, is not a good solution, that is not worth pursuing.
Then for the specific of your problem, I don't think that VTP cab be extended over router bridging, same story for wireless bridging.
