VTI Tunnels lagging problem
May 25th, 2012
Hello there,
I have some problem with IPSec VTI tunnels, here is my configuration.
There is a hub and spoke network with to hubs 3945E routers and spoke routers mostly 881 configured with two VTI tunnels,
with each hub router, and running eigrp over it. There are about 12 spoke routers.
At some point VTI tunnels started lagging, and some tunnels require "shut, no shut" command to make them work again. It seems
that when tunnel lag happens, first phase is up, and it is failing to negotiate second phase. Here is config and debug:
interface GigabitEthernet0/2.11
description WAN
encapsulation dot1Q 11
ip address x.x.x.x 255.255.255.252
crypto isakmp policy 502
encr 3des
authentication pre-share
group 2
crypto isakmp key key address y.y.y.y no-xauth
crypto ipsec transform-set AES256-SHA esp-aes 256 esp-sha-hmac
crypto ipsec profile AES256-SHA
set transform-set AES256-SHA
interface Tunnel999
description TUNNEL
ip vrf forwarding ipsec.vrf
ip address 1.1.1.1 255.255.255.252
ip mtu 1400
ip virtual-reassembly in
ip tcp adjust-mss 1300
delay 50
tunnel source x.x.x.x
tunnel mode ipsec ipv4
tunnel destination y.y.y.y
tunnel path-mtu-discovery
tunnel protection ipsec profile AES256-SHA
ip route y.y.y.y 255.255.255.255 c.c.c.c name to.branch
007563: May 24 17:26:57.380 GMT+4: ISAKMP:(1500): processing HASH payload. message ID = 2213601260
007564: May 24 17:26:57.380 GMT+4: ISAKMP:(1500): processing SA payload. message ID = 2213601260
007565: May 24 17:26:57.380 GMT+4: ISAKMP:(1500):Checking IPSec proposal 1
007566: May 24 17:26:57.380 GMT+4: ISAKMP: transform 1, ESP_AES
007567: May 24 17:26:57.380 GMT+4: ISAKMP:   attributes in transform:
007568: May 24 17:26:57.380 GMT+4: ISAKMP:      encaps is 1 (Tunnel)
007569: May 24 17:26:57.380 GMT+4: ISAKMP:      SA life type in seconds
007570: May 24 17:26:57.380 GMT+4: ISAKMP:      SA life duration (basic) of 3600
007571: May 24 17:26:57.380 GMT+4: ISAKMP:      SA life type in kilobytes
007572: May 24 17:26:57.380 GMT+4: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
007573: May 24 17:26:57.380 GMT+4: ISAKMP:      authenticator is HMAC-SHA
007574: May 24 17:26:57.380 GMT+4: ISAKMP:      key length is 256
007575: May 24 17:26:57.380 GMT+4: ISAKMP:(1500):atts are acceptable.
007576: May 24 17:26:57.380 GMT+4: ISAKMP:(1500): IPSec policy invalidated proposal with error 1024
007577: May 24 17:26:57.380 GMT+4: ISAKMP:(1500): phase 2 SA policy not acceptable! (local x.x.x.x remote y.y.y.y)
007578: May 24 17:26:57.380 GMT+4: ISAKMP: set new node -598356966 to QM_IDLE
007579: May 24 17:26:57.380 GMT+4: ISAKMP:(1500):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3 spi 537931020, message ID = 3696610330
007622: May 24 17:27:12.425 GMT+4: ISAKMP:(1500): seq. no 0x2D328AC4
007623: May 24 17:27:12.425 GMT+4: ISAKMP:(1500): sending packet to y.y.y.y my_port 500 peer_port 500 (I) QM_IDLE
007624: May 24 17:27:12.425 GMT+4: ISAKMP:(1500):Sending an IKE IPv4 Packet.
007625: May 24 17:27:12.425 GMT+4: ISAKMP:(1500):purging node -1313452134
007626: May 24 17:27:12.429 GMT+4: ISAKMP (1500): received packet from y.y.y.y dport 500 sport 500 Global (I) QM_IDLE
007627: May 24 17:27:12.429 GMT+4: ISAKMP: set new node 587467273 to QM_IDLE
007628: May 24 17:27:12.429 GMT+4: ISAKMP:(1500): processing HASH payload. message ID = 587467273
007629: May 24 17:27:12.429 GMT+4: ISAKMP:(1500): processing NOTIFY DPD/R_U_THERE_ACK protocol 1 spi 0, message ID = 587467273, sa = 0x22196288
007630: May 24 17:27:12.429 GMT+4: ISAKMP:(1500): DPD/R_U_THERE_ACK received from peer y.y.y.y, sequence 0x2D328AC4
007631: May 24 17:27:12.429 GMT+4: ISAKMP:(1500):deleting node 587467273 error FALSE reason "Informational (in) state 1"
007632: May 24 17:27:12.429 GMT+4: ISAKMP:(1500):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
007633: May 24 17:27:12.429 GMT+4: ISAKMP:(1500):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
007650: May 24 17:27:25.370 GMT+4: ISAKMP:(1499):purging node -1082779481
007651: May 24 17:27:27.257 GMT+4: ISAKMP (1500): received packet from y.y.y.y dport 500 sport 500 Global (I) QM_IDLE
007652: May 24 17:27:27.257 GMT+4: ISAKMP: set new node 1075838180 to QM_IDLE
007653: May 24 17:27:27.257 GMT+4: ISAKMP:(1500): processing HASH payload. message ID = 1075838180
007654: May 24 17:27:27.257 GMT+4: ISAKMP:(1500): processing SA payload. message ID = 1075838180
007655: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):Checking IPSec proposal 1
007656: May 24 17:27:27.257 GMT+4: ISAKMP: transform 1, ESP_AES
007657: May 24 17:27:27.257 GMT+4: ISAKMP:   attributes in transform:
007658: May 24 17:27:27.257 GMT+4: ISAKMP:      encaps is 1 (Tunnel)
007659: May 24 17:27:27.257 GMT+4: ISAKMP:      SA life type in seconds
007660: May 24 17:27:27.257 GMT+4: ISAKMP:      SA life duration (basic) of 3600
007661: May 24 17:27:27.257 GMT+4: ISAKMP:      SA life type in kilobytes
007662: May 24 17:27:27.257 GMT+4: ISAKMP:      SA life duration (VPI) of  0x0 0x46 0x50 0x0
007663: May 24 17:27:27.257 GMT+4: ISAKMP:      authenticator is HMAC-SHA
007664: May 24 17:27:27.257 GMT+4: ISAKMP:      key length is 256
007665: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):atts are acceptable.
007666: May 24 17:27:27.257 GMT+4: ISAKMP:(1500): IPSec policy invalidated proposal with error 1024
007667: May 24 17:27:27.257 GMT+4: ISAKMP:(1500): phase 2 SA policy not acceptable! (local x.x.x.x remote y.y.y.y)
007668: May 24 17:27:27.257 GMT+4: ISAKMP: set new node -1250799219 to QM_IDLE
007669: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):Sending NOTIFY PROPOSAL_NOT_CHOSEN protocol 3 spi 537931020, message ID = 3044168077
007670: May 24 17:27:27.257 GMT+4: ISAKMP:(1500): sending packet to y.y.y.y my_port 500 peer_port 500 (I) QM_IDLE
007671: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):Sending an IKE IPv4 Packet.
007672: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):purging node -1250799219
007673: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):deleting node 1075838180 error TRUE reason "QM rejected"
007674: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):Node 1075838180, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
007675: May 24 17:27:27.257 GMT+4: ISAKMP:(1500):Old State = IKE_QM_READY  New State = IKE_QM_READY
007676: May 24 17:27:30.922 GMT+4: ISAKMP: DPD received KMI message.
007677: May 24 17:27:30.922 GMT+4: ISAKMP: set new node 1679854850 to QM_IDLE
007678: May 24 17:27:30.922 GMT+4: ISAKMP:(1500):Sending NOTIFY DPD/R_U_THERE protocol 1 spi 531655060, message ID = 1679854850
007679: May 24 17:27:30.922 GMT+4: ISAKMP:(1500): seq. no 0x2D328AC5
007680: May 24 17:27:30.922 GMT+4: ISAKMP:(1500): sending packet to y.y.y.y my_port 500 peer_port 500 (I) QM_IDLE
007681: May 24 17:27:30.922 GMT+4: ISAKMP:(1500):Sending an IKE IPv4 Packet.
007682: May 24 17:27:30.922 GMT+4: ISAKMP:(1500):purging node 1679854850
007683: May 24 17:27:30.926 GMT+4: ISAKMP (1500): received packet from y.y.y.y dport 500 sport 500 Global (I) QM_IDLE
007684: May 24 17:27:30.926 GMT+4: ISAKMP: set new node 717038199 to QM_IDLE
007685: May 24 17:27:30.926 GMT+4: ISAKMP:(1500): processing HASH payload. message ID = 717038199
007686: May 24 17:27:30.926 GMT+4: ISAKMP:(1500): processing NOTIFY DPD/R_U_THERE_ACK protocol 1 spi 0, message ID = 717038199, sa = 0x22196288
007687: May 24 17:27:30.926 GMT+4: ISAKMP:(1500): DPD/R_U_THERE_ACK received from peer y.y.y.y, sequence 0x2D328AC5
007688: May 24 17:27:30.926 GMT+4: ISAKMP:(1500):deleting node 717038199 error FALSE reason "Informational (in) state 1"
007689: May 24 17:27:30.926 GMT+4: ISAKMP:(1500):Input = IKE_MESG_FROM_PEER, IKE_INFO_NOTIFY
007690: May 24 17:27:30.926 GMT+4: ISAKMP:(1500):Old State = IKE_P1_COMPLETE  New State = IKE_P1_COMPLETE
IOS version on 3945E routers is c3900e-universalk9-mz.SPA.151-4.M4.bin.
There are some tunnels configures with 3DES encryption and I have noticed that they never lag.
rizwanr74 Fri, 05/25/2012 - 15:08
Hi Franco,
Please remove those two highlighted lines and replace the "x" with your EIGRP process ID.
interface Tunnel999
description TUNNEL
ip mtu 1400
no ip split−horizon eigrp x
delay 50
Please let me know, if this helps.
thanks
frpolosr1 Sat, 05/26/2012 - 06:27
Thank you for helping,
If I disable these features won't i have problems with fragmentation ?
rizwanr74 Sat, 05/26/2012 - 08:07
These both lines do the same things one is being explicitly value is defined and other is set for auto-discovery, however when it comes tunnel interface all you need is to set the mtu size to 1400.
one:  ip tcp adjust-mss 1300
two:  tunnel path-mtu-discovery
Now when an additional command, which you need to disable split-horizon on eigrp and the "x" is your process ID, which you need for spoke-to-spoke communication, to pass via the hub.
"If I disable these features won't i have problems with fragmentation ?"
Which is taken care by setting mtu size to 1400.
Now you set the "ip tcp adjust-mss 1380" on your physical interfaces facing toward your internal switch.
Have you tried it?
thanks
Message was edited by: Rizwan Mohamed
rizwanr74 Sun, 05/27/2012 - 07:56
"crypto isakmp key key address y.y.y.y no-xauth"
I assume, you have posted your hub configuration on your very first post above on this thread.
Please change it to as shown below.
crypto isakmp key yourkey-goes-here address 0.0.0.0 0.0.0.0
crypto isakmp nat keepalive 20
On your tunnel on the hub.
interface Tunnel999
tunnel mode gre multipoint
It is better you post your hub and spoke config as I only see the pieces of the picture on this thread.
Please post as an attachement.
thanks
frpolosr1 Sun, 05/27/2012 - 09:09
All tunnels are site to site, with very simple config. I think if I implement this command "
crypto isakmp key yourkey-goes-here address 0.0.0.0 0.0.0.0 " I will lost my remoute VPN connections.
What about this command as i know it is implemented in DMVP hub router " tunnel mode gre multipoint " ?
rizwanr74 Mon, 05/28/2012 - 08:29
Hi Franco,
"crypto isakmp key yourkey-goes-here address 0.0.0.0 0.0.0.0 " I will lost my remoute VPN connections."
Assume, that your hub-site router will accept VTI tunnel neigtiation to 100 or 200 sites, in which case you would have to create 200 static-tunnel configuration but the command I showed you replaces to one.
"What about this command as i know it is implemented in DMVP hub router " tunnel mode gre multipoint " ?"
If you choose go along with static tunnel for each and every spoke-router then you would not need multipoint.
Hope that answers your question.
thanks
Related Content
