ASA 5505 router-as-a-stick, cant ping between VLANs
Hi i am trying to get my ASA 5505 with 2 internal VLANs (voice and data) and external internet VLAN to run in router as a stick, and route between VLANS.
I cant get it working though:
From the data VLAN switchport i can ping 192.168.69.1 (local VLAN) but not 192.168.70.1 (the firewall IP on other VLAN)
Connecting to the voice VLAN switchport i can ping 192.168.70.1 (local VLAN) but not 192.168.69.1 (the firewall IP on other VLAN).
I have used Watchguard firewalls before and had this working instantly, with the ASA however it is a nightmare.
Can you please let me know what i am doing wrong and how i can make the ASA route between subnets?
Chris
Result of the command: "show running"
: Saved
ASA Version 8.4(4)
hostname ciscoasa
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 70
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.69.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan70
no forward interface Vlan2
nameif voice
security-level 100
ip address 192.168.70.1 255.255.255.0
boot system disk0:/asa844-k8.bin
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj-192.168.69.0
subnet 192.168.69.0 255.255.255.0
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj-192.168.70.0
subnet 192.168.70.0 255.255.255.0
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
access-list inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 192.168.69.0 255.255.255.0 192.168.70.0 255.255.255.0
access-list voice_access_in extended permit object-group DM_INLINE_PROTOCOL_2 192.168.70.0 255.255.255.0 192.168.69.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu voice 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
nat (inside,voice) static 192.168.69.0
nat (inside,outside) dynamic interface
nat (voice,inside) static 192.168.70.0
access-group inside_access_in in interface inside
access-group voice_access_in in interface voice
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.69.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh 192.168.69.0 255.255.255.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.69.5-192.168.69.254 inside
dhcpd enable inside
threat-detection basic-threat
no threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
: end
Overall Rating: 5 (2 ratings)
varrao Fri, 05/25/2012 - 16:23
  • Red, 2250 points or more
What is the license that you have on the device?
Varun Rao
Security Team,
Cisco TAC
varrao Fri, 05/25/2012 - 16:35
With Base license you would have a dmz restricted license, if you do " show version" on cli, you would see it.
This means you can only have 2 regular zones which can communicate with each other and the 3rd one which is restricted, traffic can only be initiated from one vlan.
Here's the license doc:
http://www.cisco.com/en/US/docs/security/asa/asa82/license/license82.html#wp190062
Varun Rao
Security Team,
Cisco TAC
Julio Carvajal Fri, 05/25/2012 - 16:36
  • Purple, 4500 points or more
Important thing for you to know:
1- In order to allow ICMP packets to traverse the ASA you need to statefully inspect the ICMP protocol.
2- You cannot ping a distant interface , what does this mean? R/ if you are behind the inside interface you will be able to ping it but you will not be able to ping the outside interface Ip add or the DMZ interface Ip add. This is a built-in security meassure.
3- ASA 5505 with a Base license ( Traffic will only be allow ( unrestricted) from 2 vlans, the 3 one will be restricted, This means the 3 vlan will only be able to talk to one other interface not to both of them.
In order to change the behavior of the traffic that will be allow by the 3rd vlan you need the following command:
- no forward interface vlan #
To solve this you will need a plus license.
Do rate all the helpful posts
Julio
Security Engineer
Related Content
