Nexus 5596 svi - strange
Answered Question
hi all,
I currently got 2 nexus 5596 to do some tests
First of all i wanted to create a management if without using mgmt0 (i use this if for vpc-peer)
So what i did is:
create a vlan
create a vrf
enable feature interface-vlan
create a interface vlan within this vrf and set a ip
enable a trunk with this vlan
on one of the nexus it works, on the other not .. really strange
vlan is up and got a spanning-tree forwarding port
but on the strange switch the layer 3 if is down/down
both switches are 5596 with 5.1.3
anyone ever experienced such an issue?
thanks!
Correct Answer by Arthur Cruz about 4 years 9 months ago
Hmm, sounds strange. Can you verify it came with the base license installed. I've seen that before where the base license didn't get installed and the switch wouldn't do something. I can't remember if it was that the SVI wouldn't come online or something else...
Overall Rating: 5 (1 ratings)
Arthur Cruz Sat, 05/26/2012 - 08:55
Do you mean for the peer keepalive link? Do you have M or F cards?
Arthur Cruz Sat, 05/26/2012 - 09:11
Oh ya ><
It sounds like a vPC issue maybe.
What does a "sh vPC" on each switch show? Also, can you post the vPC and peer link config?
it have the same issue if i remove the vpc config und just add a normal trunk between both switches (even after wr er)
Here are some details (vlan 3801 is used for l3):
Working switch:
switch2# sho inter vlan 3801
Vlan3801 is up, line protocol is up
  Hardware is EtherSVI, address is  547f.ee09.e6c1
  Internet Address is 172.24.128.5/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
switch2# sho vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 10
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary, operational primary
Number of vPCs configured       : 1
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po1    up     3801-3811
vPC status
id     Port        Status Consistency Reason                     Active vlans
10     Po10        up     success     success                    3801-3811
on the other switch:
switch1# sho inter vlan 3801
Vlan3801 is down, line protocol is down
  Hardware is EtherSVI, address is  547f.ee2f.d2c1
  Internet Address is 172.24.128.6/24
switch1# sho vpc
Legend:
vPC domain id                   : 10
vPC role                        : primary, operational secondary
1    Po1    up     3801-3811
vPC status
switch1# sho vlan id 3801
VLAN Name                             Status    Ports
3801 vmware_mng                       active    Po1, Po10
switch1# sho feature | i enabled
fex                   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
sshServer             1         enabled
telnetServer          1         enabled
udld                  1         enabled
vpc                   1         enabled
Correct Answer
Arthur Cruz Sat, 05/26/2012 - 10:01
Arthur Cruz Sat, 05/26/2012 - 10:14
Ya that makes sense. I've seen it before where the missing base license caused problems with some L3 feature, I just couldn't remember if it was specifically the SVI wouldn't go up.
Arthur Cruz Sat, 05/26/2012 - 10:24
No the L3 card requires the advanced license, the 5596 wont even recognize the L3 daughtercard without the advanced license, but there are basic L3 stuff the switch will do, apparently only with the base license.
Arthur Cruz Sat, 05/26/2012 - 10:48
The grace period didn't kick in when you cleared the license did it?
not that i noticed. here's the output from clearing the lic:
clear license xxx.lic
Clearing license xxx.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_BASE_SERVICES_PKG cisco 1.0 permanent uncounted \
        VENDOR_STRING=MDS_SWIFTN55-BAS1K9= \
        HOSTID=VDH=xxx \
        NOTICE="xxx1 \
        " SIGN=xxx
Do you want to continue? (y/n) y
Clearing license ......2012 May 26 17:14:53 N5k5POC01 %$ VDC-1 %$ %LICMGR-1-LOG_LIC_LICENSE_EXPIRED: Evaluation license expired for feature LAN_BASE_SERVICES_PKG.
done
Arthur Cruz Sat, 05/26/2012 - 11:05
what does your "sh license usage" look like now?
Arthur Cruz Sat, 05/26/2012 - 11:06
I'd try to reinstall the base license and see if it breaks again.
befor installing the lic:
switch1# sho lic usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FCOE_NPV_PKG                  No    -   Unused             -
FM_SERVER_PKG                 Yes   -   Unused 21 Jan 2013 -
ENTERPRISE_PKG                Yes   -   Unused 03 May 2013 -
FC_FEATURES_PKG               Yes   -   Unused 03 May 2013 -
VMFEX_FEATURE_PKG             No    -   Unused             -
ENHANCED_LAYER2_PKG           Yes   -   Unused 21 Jan 2013 -
LAN_BASE_SERVICES_PKG         No    -   Unused             -
LAN_ENTERPRISE_SERVICES_PKG   Yes   -   Unused Never       -
after installing:
N5k5POC01# sho lic usage
                                 Count
LAN_BASE_SERVICES_PKG         Yes   -   In use Never       -
switch1# sho inter vlan 3811
Vlan3811 is down, line protocol is down
Installing the base lic breaks the svi
Arthur Cruz Sat, 05/26/2012 - 11:21
I wonder if the enterprise license is inclusive or incremental. With the base license cleared see if you still have HSRP commands. If so we know its inclusive and I'd just leave the base license uninstalled since you have the enterprise license.
I don't remember having trouble with both licenses, but the few 5596 implementations I've done with a L3 daughtercard/enterprise license I've never really paid attention if the base license is installed as well, I just always assumed it was.
Arthur Cruz Sat, 05/26/2012 - 11:39
Yes, HSRP is part of the base license, it does not require the L3 card. The L3 card basically expands the routing table and improves forwarding. The L3 daughtercard requires the enterprise license.
Did you buy the enterprise license? If so, what I meant was keep the enterprise license installed, clear the base license and see if the HSRP commands are available. If they are then we know the enterprise license covers all the base license stuff and you can leave it like that.
Arthur Cruz Sat, 05/26/2012 - 11:46
CORRECTION:
The L3 card requires the base license to be installed, not the enterprise. But, the base license doesn't require the L3 card.
Arthur Cruz Sat, 05/26/2012 - 11:52
I dunno, maybe I'm going crazy and all L3 feature require the L3 expansion module... I'm digging around the internet...
Arthur Cruz Sat, 05/26/2012 - 11:57
Yeah, I totally miss-read the datasheets, the V2 expansion card expands the routing table from the previous version, not that its the only thing it does. And now that I think about it, the only 5500 implementations I've done that included routing have also had the L3 card :\
I'm post sales not pre-sales so I don't usually have to deal with that stuff ><
Anyway, looks like if you need to route between those vlans you're going to have to bounce it off a router or install the L3 expansion module.
Arthur Cruz Sat, 05/26/2012 - 12:06
ya it does, you should be able to get the SVI online for management, you just wouldn't be able to use a routing protocol or route between SVIs.
Really weird though that if they require the L3 card the SVI would come online with the enterprise license and without the base license.
I'm really curious, with the enterprise license installed does it let you configure any routing protocols?
this thing is a bit strange
with enterprise without base lic:
feature eigrp
No available license - LAN_BASE_SERVICES_PKG error Feature does not have an inst
alled license
with both lic installed i can enable eigrp:
router eigrp 10
  vrf poc_vpc
    address-family ipv4 unicast
      autonomous-system 123
but the svi is down
Arthur Cruz Sat, 05/26/2012 - 12:23
Ya so it sounds like what it's doing is without the licensing you can use the svi for management, but you can't route because you can't enable the routing protocol features. Once you install the licensing it then says nice try, even though you can now enable/configure the feature I'll just kill the SVI because you still need the L3 card. You'd think instead of killing the SVI they'd just add in an additional check for the card when you try to enable the routing protocol feature.
Weird.
pankudin Wed, 02/27/2013 - 06:46
To reduce confusion around:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/release/notes/Rel_5_2_1_N1_1/Nexus5000_Release_Notes_5_2_1_N1.html#wp355966
So, L3 interfaces (including SVI) are not supported without L3 module or "management" keyword under SVI configuration.
LAN_BASE_SERVICES_PKG license is necessary when L3 module is installed and activates additional processes on 5k.
If you do not have L3 module on you device - please do not try to fix that just by removing LAN_BASE_SERVICES_PKG. Removing this license without module is good idea, but you still have to configure "management" under SVI.
