Warning message
IPSEC VTI and OSPF
May 26th, 2012
I have 5 routers (soon to be 6) with tunnels (all VTI) between them.
I also have a basic OSPF setup running here (previously it was RIP), and all networks can talk to each other, however there is one routing issue, where it takes a longer path to the remote network.
The Configs:
R1:
interface Tunnel0
description tunnel to detroit office
ip address 172.28.40.1 255.255.255.0
ip ospf network broadcast
ip ospf mtu-ignore
tunnel source xx
tunnel destination xxx
tunnel mode ipsec ipv4
tunnel protection ipsec profile VTI
interface Tunnel1
description tunnel to San Diego Office
ip address 172.28.42.1 255.255.255.0
ip ospf mtu-ignore
tunnel source xxx
interface Tunnel2
description tunnel to Detroit DC
ip address 172.28.43.1 255.255.255.0
ip ospf mtu-ignore
tunnel source xxx
interface Tunnel3
description tunnel to detroit office - standby
ip address 172.28.51.1 255.255.255.0
ip ospf mtu-ignore
tunnel source GigabitEthernet0/0
router ospf 42
log-adjacency-changes
network 10.87.1.0 0.0.0.255 area 0
network 172.28.40.0 0.0.0.255 area 0
network 172.28.42.0 0.0.0.255 area 0
network 172.28.43.0 0.0.0.255 area 0
network 172.28.51.0 0.0.0.255 area 0
cerberus#sh ip route ospf
     172.28.0.0/24 is subnetted, 7 subnets
O       172.28.49.0 [110/2000] via 172.28.42.2, 05:47:06, Tunnel1
O       172.28.50.0 [110/2000] via 172.28.42.2, 05:47:06, Tunnel1
O       172.28.41.0 [110/2000] via 172.28.42.2, 05:47:06, Tunnel1
                    [110/2000] via 172.28.40.2, 05:47:06, Tunnel0
     10.0.0.0/24 is subnetted, 2 subnets
O       10.87.2.0 [110/2001] via 172.28.42.2, 05:47:06, Tunnel1
O    192.168.1.0/24 [110/1001] via 172.28.42.2, 05:47:06, Tunnel1
O    192.168.2.0/24 [110/1001] via 172.28.40.2, 05:47:06, Tunnel0
cerberus#
As you can see for 10.87.2.x it is going through the 192 network, when it has a direct tunnel through tunnel 2
R2:
interface Tunnel0
description tunnel to AIS San Diego
ip address 172.28.42.2 255.255.255.0
ip ospf mtu-ignore
interface Tunnel1
ip address 172.28.41.1 255.255.255.0
ip ospf mtu-ignore
interface Tunnel2
description tunnel to Detroit Data Center
ip address 172.28.49.1 255.255.255.0
ip ospf mtu-ignore
interface Tunnel3
description tunnel to Detroit t1 router
ip address 172.28.50.1 255.255.255.0
ip ospf mtu-ignore
router ospf 42
network 172.28.41.0 0.0.0.255 area 0
network 172.28.49.0 0.0.0.255 area 0
network 172.28.50.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
#sh ip route ospf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 24.43.240.137 to network 0.0.0.0
O        10.87.1.0 [110/1001] via 172.28.42.1, 03:55:51, Tunnel0
O        10.87.2.0 [110/1001] via 172.28.49.2, 03:55:51, Tunnel2
      172.28.0.0/16 is variably subnetted, 11 subnets, 2 masks
O        172.28.40.0/24 [110/2000] via 172.28.42.1, 03:55:51, Tunnel0
                        [110/2000] via 172.28.41.2, 03:55:51, Tunnel1
O        172.28.43.0/24 [110/2000] via 172.28.49.2, 03:55:51, Tunnel2
O        172.28.51.0/24 [110/2000] via 172.28.50.2, 03:55:51, Tunnel3
O     192.168.2.0/24 [110/1001] via 172.28.50.2, 03:55:51, Tunnel3
                     [110/1001] via 172.28.41.2, 03:55:51, Tunnel1
r2 is the route that r1 ends up using when connecting to 10.87.2.x
Any advice on one, how to fix this, and two on the general setup would be wonderful. I am new to ospf and feels like I could have done a better job here (maybe using an area per site)
Jennifer Halim Sat, 05/26/2012 - 20:18
  • Cisco Employee,
There doesn't seem to be a tunnel with
172.28.43.0/24 subnet configured on R2 and 172.28.43.0/24 is not advertised on R2 on OSPF. Looks like you might have been missing this particular tunnel on R2 hence the issue.
searchoptics_2011 Sat, 05/26/2012 - 20:26
R2 is the router R1 is using to get to the destination that Tunnel 1 on R1 is connected to
Tunnel 1 on R3 is a VTI tunnel to Tunnel 3 on R1.
R1 is currently using tunnel 1 on R1 to hop to R2 and then uses tunnel 2 to get to R3
If that makes sense..
Here is the config for R3
interface Tunnel1
ip address 172.28.43.2 255.255.255.0
ip ospf mtu-ignore
tunnel source xxx
interface Tunnel2
description tunnel to San Diego Main Office
ip address 172.28.49.2 255.255.255.0
ip ospf mtu-ignore
tunnel source xxx
router ospf 42
network 10.87.2.0 0.0.0.255 area 0
sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
Gateway of last resort is 199.16.189.209 to network 0.0.0.0
C       172.28.49.0 is directly connected, Tunnel2
O       172.28.50.0 [110/2000] via 172.28.49.1, 02:32:05, Tunnel2
O       172.28.51.0 [110/3000] via 172.28.49.1, 02:32:05, Tunnel2
O       172.28.40.0 [110/3000] via 172.28.49.1, 02:32:05, Tunnel2
O       172.28.41.0 [110/2000] via 172.28.49.1, 02:32:05, Tunnel2
O       172.28.42.0 [110/2000] via 172.28.49.1, 02:32:05, Tunnel2
C       172.28.43.0 is directly connected, Tunnel1
O       10.87.1.0 [110/2001] via 172.28.49.1, 02:32:05, Tunnel2
C       10.87.2.0 is directly connected, GigabitEthernet0/1
     199.16.189.0/28 is subnetted, 1 subnets
C       199.16.189.208 is directly connected, GigabitEthernet0/0
O    192.168.1.0/24 [110/1001] via 172.28.49.1, 02:32:05, Tunnel2
O    192.168.2.0/24 [110/2001] via 172.28.49.1, 02:32:05, Tunnel2
searchoptics_2011 Sat, 05/26/2012 - 20:36
and got it, needed to put
on tunnel 1
now the routes look correct.. damn that's embarassing.
Jennifer Halim Sun, 05/27/2012 - 01:55
  • Cisco Employee,
Ahh OK, got it, R3 wasn't in the picture earlier
Thanks for the update..
rahimbhamani Thu, 01/17/2013 - 22:19
Ipsec profile VTI name applied to how many tunnels. In our case there are 500 + Branches. We created point to point tunnel at hub site for all Branches.Can we apply same ipsec profile VTI(same profile) to all the tunnels interfaces
Related Content
