Start and Stop Recording on Cisco agent Desktop
vaibhav-g
I have Integrated my UCCX 8.0.1 SU2 to AQM 8.6.2.
I just want to know how can an agent Start and Stop recording on demand.How we can integrate this feature in CAD software or CSD Software
What all steps need to perform on UCCX CUCM and AQM to run this feature
Plse find the screenshot for the same.
Vaibhav Gupta
Go to the cisco desktop administrator, under the workflow , select default and after that select CAD agent
Then select User Interface
From the right Panel scrol down to tasks , pick anyone from the 10 and click on visible
After that click the add button below it.
Another page will open , choose the Utility action tab then click on new :
Action name : StartRecording
ActionType : Record
Action : Start
Then add another action
Action name : Stop recording
Action Type : Record
Action : Stop
Then choose the start recording and click add action , it will return to the first page, click on add one more time and choose the utility action , then choose the stop recording action and click on add action, apply the config and then do a synchronize for the services and close the CAD and reopen it , it should work.
Amer
ActionType : Record
Action : Start
Action : Stop
Amer
Hi Amer
Thanks a lot for your solution , I have just small query
Will this Start and Stop Function stop and start recording on AQM server.
AQM is integrated with UCCX so in AQM all calls get recorded for voce + Screen as well as Voice recording Only
I just want to Start and Stop these recording from CAD and CSD software
Vaibhav
