ASA 5510 vlan cannot reach wan
Answered Question
May 28th, 2012
Hi everyone,
i'm setting up vlan and inter-vlan routing in my lab. My vlan work well (routing between them and dhcp relay) on the LAN side of the ASA but they cannot reach internet trough the ASA.
I read a lot about this issue and tried different configurations but i can't solve it...
Exemple of what i read and tried
Here my ASA settings :
Note : I know that the physical interface musn't have an @IP but my present network needs one to work. I'll fix this during my next tests.
: Saved
ASA Version 8.2(1)
hostname CISCOASA
domain-name MEDIAMEETING
enable password *********** encrypted
passwd ********** encrypted
names
name 192.168.0.2 mediaserv
name 192.168.2.200 Routeur-Fullsave description Routeur Fullsave
name 91.197.164.8 Serveur-streaming description Serveur de streaming distant
name 193.252.220.135 FM47
name 79.174.207.220 SNCF
name 80.13.227.86 TLSEFM
name 79.174.204.201 ALTITUDE
name 212.234.48.67 BDX
name 192.168.4.254 Freebox description Freebox
dns-guard
interface Ethernet0/0
nameif WAN_FREE
security-level 10
ip address 192.168.4.253 255.255.255.0 standby 192.168.4.250
interface Ethernet0/1
description connexion vers le LAN via switch cisco
nameif LAN
security-level 100
ip address 192.168.0.4 255.255.255.0 standby 192.168.0.6
interface Ethernet0/1.31
vlan 31
nameif vlan_postes
security-level 100
ip address 192.168.31.254 255.255.255.0
interface Ethernet0/1.200
vlan 200
nameif vlan_winradio
security-level 100
ip address 192.168.200.250 255.255.255.0
interface Ethernet0/2
description Connexion Free et fibre
speed 100
duplex full
nameif WAN_Fibre
security-level 10
  ip address 192.168.2.253 255.255.255.0 standby 192.168.2.250
interface Ethernet0/3
description LAN Failover Interface
interface Management0/0
nameif management
security-level 100
management-only
boot system tftp://192.168.0.2/modifpass
boot system disk0:/asa821-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network Acces-distant
network-object host FM47
network-object host SNCF
network-object host TLSEFM
network-object host BDX
object-group network MM-Acces-distant
network-object 192.168.0.0 255.255.255.0
object-group service RAdmin tcp
description Port RAdmin
port-object eq 4899
access-list LAN_pnat_outbound extended permit ip host 192.168.0.56 171.16.135.216 255.255.255.248
access-list LAN_nat0_outbound extended permit ip 192.168.97.80 255.255.255.248 171.16.135.216 255.255.255.248
access-list LAN_nat0_outbound extended permit ip any 192.168.0.128 255.255.255.128
access-list LAN_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.0.128 255.255.255.128
access-list LAN_nat0_outbound extended permit ip host 192.168.0.187 192.168.248.0 255.255.255.0 inactive
access-list LAN_nat0_outbound extended permit ip host 192.168.0.56 192.168.248.0 255.255.255.0 inactive
access-list LAN_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.128
access-list LAN_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list LAN_nat0_inbound extended permit ip any 192.168.0.128 255.255.255.128
access-list Mediameet_splitTunnelAcl standard permit 192.168.0.0 255.255.255.0
access-list Mediameet_splitTunnelAcl standard permit 192.168.31.0 255.255.255.0
access-list WAN_Access_In2 extended permit tcp any host 192.168.2.253 eq 3389 inactive
access-list WAN_Access_In2 extended permit tcp any host 192.168.2.253 eq 3390 inactive
access-list WAN_Access_In2 remark Acces RAdmin Principal
access-list WAN_Access_In2 extended permit tcp any host 192.168.2.253 eq 4899
access-list LAN_nat0_inbound.20 extended permit ip any 192.168.3.0 255.255.255.128
access-list global_mpc_1 remark exemple priorisation Prise de main à distance
access-list global_mpc_1 extended permit ip object-group MM-Acces-distant object-group Acces-distant
access-list streaming extended permit ip any host Serveur-streaming
access-list Mediameet_splitTunnelAcl_1 standard permit 192.168.0.0 255.255.255.0
access-list WAN_FREE_access_in_1 remark Acces RAdmin de secours
access-list WAN_FREE_access_in_1 extended permit tcp any host 192.168.4.253 eq 4899
pager lines 24
logging enable
logging asdm informational
logging from-address ******
logging recipient-address ******
mtu WAN_FREE 1500
mtu LAN 1500
mtu WAN_Fibre 1500
mtu vlan_postes 1500
mtu vlan_winradio 1500
mtu management 1500
ip local pool RemoteConn 192.168.3.1-192.168.3.128 mask 255.255.255.0
failover
failover lan unit primary
failover lan interface STATEFUL Ethernet0/3
failover replication http
failover interface ip STATEFUL 10.0.0.1 255.255.255.252 standby 10.0.0.2
no monitor-interface management
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
global (WAN_FREE) 1 interface
global (WAN_Fibre) 1 interface
nat (LAN) 0 access-list LAN_nat0_outbound
nat (LAN) 0 access-list LAN_nat0_inbound outside
nat (LAN) 1 0.0.0.0 0.0.0.0
nat (vlan_postes) 1 192.168.31.0 255.255.255.0
nat (vlan_postes) 1 0.0.0.0 0.0.0.0
static (LAN,WAN_Fibre) tcp interface 4899 192.168.0.56 4899 netmask 255.255.255.255
static (vlan_postes,WAN_Fibre) 192.168.31.0 192.168.31.0 netmask 255.255.255.0
static (WAN_Fibre,vlan_postes) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
access-group WAN_FREE_access_in_1 in interface WAN_FREE
access-group WAN_Access_In2 in interface WAN_Fibre
route WAN_Fibre 0.0.0.0 0.0.0.0 Routeur-Fullsave 64 track 1
route WAN_FREE 0.0.0.0 0.0.0.0 Freebox 62
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.0.0 255.255.0.0 LAN
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 1
type echo protocol ipIcmpEcho Routeur-Fullsave interface WAN_Fibre
sla monitor schedule 1 life forever start-time now
service resetoutside
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map WAN_dyn_map 20 set pfs group1
crypto dynamic-map WAN_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map WAN_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map WAN_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map WAN_dyn_map 40 set transform-set ESP-3DES-SHA
crypto dynamic-map WAN_dyn_map 40 set security-association lifetime seconds 28800
crypto dynamic-map WAN_dyn_map 40 set security-association lifetime kilobytes 4608000
crypto dynamic-map WAN_dyn_map 60 set transform-set ESP-3DES-SHA
crypto dynamic-map WAN_dyn_map 60 set security-association lifetime seconds 28800
crypto dynamic-map WAN_dyn_map 60 set security-association lifetime kilobytes 4608000
crypto dynamic-map FREE_dyn_map 20 match address LAN_nat0_inbound.20
crypto dynamic-map FREE_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map FREE_dyn_map 20 set security-association lifetime seconds 28800
crypto dynamic-map FREE_dyn_map 20 set security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map WAN_map_FREE 20 ipsec-isakmp dynamic FREE_dyn_map
crypto map WAN_map_FREE interface WAN_Fibre
crypto ca trustpoint ASDM_SSLMM
enrollment terminal
subject-name CN=CISCOASA
  crl configure
crypto ca trustpoint localtrust_Free
crypto ca trustpoint localtrust_Fibre
crypto ca certificate chain localtrust_Free
  quit
crypto ca certificate chain localtrust_Fibre
  quit
crypto isakmp identity hostname
crypto isakmp enable WAN_Fibre
crypto isakmp enable management
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
track 1 rtr 1 reachability
client-update enable
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
telnet 192.168.0.0 255.255.255.0 LAN
telnet 192.168.3.0 255.255.255.128 LAN
telnet timeout 10
ssh timeout 5
console timeout 0
management-access LAN
dhcpd address 192.168.1.2-192.168.1.254 management
dhcprelay server 192.168.0.1 LAN
dhcprelay enable vlan_postes
dhcprelay enable vlan_winradio
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
ssl trust-point localtrust_Fibre WAN_Fibre
ssl trust-point localtrust_Free WAN_FREE
webvpn
group-policy DfltGrpPolicy attributes
group-policy Mediameet internal
group-policy Mediameet attributes
group-policy Mediameet_1 internal
group-policy Mediameet_1 attributes
group-policy MediaSSL internal
group-policy MediaSSL attributes
username ******* password ****** encrypted privilege 0
username ********* attributes
vpn-group-policy Mediameet
class-map WinRadio-class
description limitation bande Passante à 1Mbits/s
match any
class-map global-class
match default-inspection-traffic
class-map Streaming-class
match any
class-map SITES-DISTANTS
description exemple priorisation Prise de main à distance
match access-list global_mpc_1
class-map global-class1
match port tcp range 3389 3390
class-map global-class2
description Préparation streaming 2mbps
match port tcp range 9252 9256
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum 512
  message-length maximum client auto
policy-map global-policy
description default_inspection
class global-class1
  priority
class global-class2
  police input 2097000 1500
  police output 2097000 1500
class SITES-DISTANTS
  priority
class global-class
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
   inspect tftp
  inspect xdmcp
policy-map WinRadio-policy
class WinRadio-class
  police input 1024000 1500
  police output 1024000 1500
policy-map Streaming-policy
class Streaming-class
  police output 3072000 1536
prompt hostname priority state
Cryptochecksum:*************
: end
I apologize for my english and thank you for your interest.
Correct Answer by Jennifer Halim about 4 years 8 months ago
The reason why you can't ping is because you have the following configured:
I believe that you need that for your VPN, so please configure Nonat instead:
access-list vlan_postes_nonat permit ip 192.168.31.0 255.255.255.0 192.168.3.0 255.255.255.0
nat (vlan_postes) 0 access-list vlan_postes_nonat
And remove the above static NAT statements.
Then "clear xlate". Ping should work after the above changes.
Overall Rating: 5 (1 ratings)
Jennifer Halim Mon, 05/28/2012 - 00:56
which particular vlan can't access the Internet?
you would need to have a NAT statement for those vlans so it gets PATed to the WAN_FREE interface IP Address (public IP) to be able to reach the internet.
So far, only the following interface will have access to the internet:
LAN and vlan_postes:
Mediadeshaies Mon, 05/28/2012 - 01:19
Hello Jennifer Halim,
Actually, only vlan_postes needs to access the internet. So i set the NAT but it doesn't work.
I don't understand very well what you mean by
Do i have to set something more than
Or may my ACL be the problem ?
Jennifer Halim Mon, 05/28/2012 - 02:29
you have not applied the global-policy yet:
service-policy global-policy global
Then try to ping 4.2.2.2 and see if you get a reply.
Mediadeshaies Mon, 05/28/2012 - 05:12
i tried to apply what you said, it displayed this message:
ERROR: Class global-class1 has 'priority' set without 'priority-queue' in any interface
So i tried this :
CISCOASA/pri/act(config)# policy-map global-policy
CISCOASA/pri/act(config)# no class global-cass1
And it displayed :
ERROR: % class-map global-class1 is being used
My knowledge about ASA and policy in general is really poor. So i'm a bit lost
Do you have any idea?
Thank you
Jennifer Halim Mon, 05/28/2012 - 05:18
Just create a new policy and apply it as follows:
policy-map global_policy
class global-class
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
   inspect tftp
  inspect xdmcp
service-policy global_policy global
Mediadeshaies Tue, 05/29/2012 - 02:13
here the configuration after i tried your solution. New lines appeared but ping still not working (4.2.2.2 or 8.8.8.8).
Note : i removed the @IP from the physical interface ethernet 0/1 before to do the test
: Saved
: Written by enable_15 at 10:19:52.898 CEDT Tue May 29 2012
ASA Version 8.2(1)
hostname CISCOASA
passwd *********** encrypted
names
dns-guard
description Ex liaison Altitude Telecom
nameif WAN_FREE
security-level 10
nameif LAN
security-level 100
no ip address
vlan 31
nameif vlan_postes
security-level 100
vlan 200
security-level 100
speed 100
duplex full
nameif WAN_Fibre
security-level 10
nameif management
security-level 100
management-only
ftp mode passive
port-object eq 4899
access-list WAN_FIBRE_access_in remark Accs RAdmin depuis WAN - Principal
access-list WAN_FREE_access_in remark Accs RAdmin depuis WAN - Secours
pager lines 24
logging enable
logging from-address *****************
logging recipient-address **************level emergencies
mtu WAN_FREE 1500
mtu LAN 1500
mtu WAN_Fibre 1500
mtu management 1500
failover
asdm location ALTITUDE 255.255.255.255 LAN
arp timeout 14400
route WAN_FREE 0.0.0.0 0.0.0.0 Freebox 128
http server enable
sla monitor 1
enrollment terminal
crl configure
enrollment self
fqdn ************
email ****************
subject-name CN=ssl.666.mediameeting.net
ip-address ******************
keypair ****************
crl configure
enrollment self
fqdn *******************
email ******************
subject-name CN=**************
crl configure
certificate cbdcbd4f
    30820247 308201b0 a0030201 020204cb dcbd4f30 0d06092a 864886f7 0d010104
  quit
certificate b5debd4f
    3082023f 308201a8 a0030201 020204b5 debd4f30 0d06092a 864886f7 0d010104
  quit
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 10
ssh timeout 5
console timeout 0
webvpn
enable WAN_FREE
enable WAN_Fibre
svc image disk0:/anyconnect-win-2.5.3055-k9.pkg 1
svc image disk0:/anyconnect-macosx-i386-2.5.3055-k9.pkg 2 regex "Intel Mac OS X"
svc image disk0:/anyconnect-linux-2.5.3055-k9.pkg 3 regex "Linux"
svc image disk0:/anyconnect-dart-win-2.5.3055-k9.pkg 4
svc profiles DefaultProfile disk0:/defaultprofile.xml
svc enable
tunnel-group-list enable
dns-server value 192.168.0.1 8.8.8.8
dns-server value 192.168.0.2 192.168.0.1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Mediameet_splitTunnelAcl
default-domain value MEDIAMEETING
wins-server none
vpn-tunnel-protocol IPSec
split-tunnel-network-list value Mediameet_splitTunnelAcl_1
vpn-tunnel-protocol svc webvpn
default-domain value MEDIAMEETING.local
msie-proxy method no-modify
vlan none
address-pools value RemoteConn
webvpn
  url-list none
  svc keep-installer installed
  svc modules value dart,vpngina
  svc ask enable default webvpn timeout 30
username j.deshaies password LO5lB1rnyhGb/fvs encrypted privilege 0
username j.deshaies attributes
username jl.simonet password AGYq7x1Zyk3V2dQJ encrypted privilege 0
username jl.simonet attributes
username b.niberon password GK4IufRVHvPpPLoX encrypted privilege 0
username b.niberon attributes
username s.ternoir password mYWJMd1aRkM.1tjc encrypted privilege 0
username s.ternoir attributes
username c.casse password MdCJ1tgbh5jQIiXJ encrypted privilege 15
username c.casse attributes
service-type admin
webvpn
  svc profiles value DefaultProfile
username a.hugounenq password ItUfDhv1D9cwmFvZ encrypted privilege 15
tunnel-group ********* type ipsec-l2l
tunnel-group ************* ipsec-attributes
pre-shared-key *
tunnel-group Mediameet type remote-access
tunnel-group Mediameet general-attributes
address-pool RemoteConn
default-group-policy Mediameet_1
tunnel-group Mediameet ipsec-attributes
pre-shared-key Amandine0804
tunnel-group ******** type ipsec-l2l
tunnel-group ********** ipsec-attributes
pre-shared-key MeD1A!!M2ET1ng
tunnel-group SSL_MM type remote-access
tunnel-group SSL_MM general-attributes
authentication-server-group (LAN) LOCAL
default-group-policy MediaSSL
tunnel-group SSL_MM webvpn-attributes
group-alias PostesDistants enable
tunnel-group-map default-group Mediameet
match any
match any
parameters
class global-class
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
class global-class1
  priority
class global-class2
  priority
class global-class
  inspect esmtp
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect netbios
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect xdmcp
Cryptochecksum:dd605e032202ff6791c19afc056b3757
: end
My host ipconfig (the one which execute ping) :
@IP: 192.168.31.2
Defaut gateway : 192.168.31.254
DHCP : 192.168.0.1
DNS : 192.168.0.1
secondary DNS : 8.8.8.8
Thank you for your attention.
Correct Answer
Jennifer Halim Tue, 05/29/2012 - 04:34
Mediadeshaies Tue, 05/29/2012 - 05:14
it works! Thank you very much for your help
Have a good day
