Does 2801 router support SPA50x phones?
May 28th, 2012
Hi All.
We've got a 2801 router CME4.2 and I'm trying to use SPA502G phone with it. Phone shows "Registering" only, and the router shows "
046585: May 28 09:03:16.224: TFTP: Looking for /SPA502G-cfg.xml".
Does this router support SPA50x phones?
If it does what am I missing there? Some files on a flash (I uploaded only .bin file there)?
Where can I get a list of files which should be uploaded to the router's flash?
Thanks.
firestormnet Mon, 05/28/2012 - 06:24
Thanks Paolo.
That's what I thought as I couldn't find anything.
Carlo Poggiarelli Thu, 03/06/2014 - 07:56
Hi.
Being a Sip based phone, yes it works
Carlo
Please rate all helpful posts
"The more you help the more you learn"
dangquangminh Thu, 03/06/2014 - 08:05
Thanks Carlo for your reply.
I can not change the phone from SCSP to SIP mode from its menu.
Can we change between sip and scsp on that phone? Or default it will boot up with sip?
Carlo Poggiarelli Thu, 03/06/2014 - 08:15
SPA 502 default is SIP
Carlo
dangquangminh Thu, 03/06/2014 - 08:34
Could you please have a look at the CCME configs. Am i missing any command? Currently the SPA502G can obtain its IP address but it can not register with the CCME.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
bind control source-interface GigabitEthernet0/0.2
bind media source-interface GigabitEthernet0/0.2
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 5 clear-channel
voice register global
mode cme
source-address 10.9.206.2 port 5060
max-dn 200
max-pool 42
load 7942 SIP42.9-3-1SR2-1S
authenticate register
mwi stutter
voicemail 7400
tftp-path flash:
file text
create profile sync 0393213362631131
voice register dn 30
number 4030
no-reg
voice register dn 31
number 4031
allow watch
name Shop Floor 1
label Shop Floor 1
voice register pool 30
id mac ECE1.A9CD.0723
number 1 dn 30
dtmf-relay rtp-nte
voice-class codec 1
username 4030 password 4030
description gateway of vlan 2
encapsulation dot1Q 2
ip address 10.9.206.2 255.255.255.0
ip helper-address 10.9.205.65
h323-gateway voip interface
tftp-server flash0
tftp-server flash:term42.default.loads
tftp-server flash:SIP42.9-3-1SR2-1S.loads
tftp-server flash:jar42sip.9-3-1ES13.sbn
tftp-server flash:apps42.9-2-1TH1-13.sbn
tftp-server flash:cnu42.9-2-1TH1-13.sbn
tftp-server flash:cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash:dsp42.9-2-1TH1-13.sbn
tftp-server flash:jar42sccp.9-2-1TH1-13.sbn
tftp-server flash:SCCP42.9-2-1S.loads
tftp-server flash:term62.default.loads
tftp-server flash:cue-installer.SPA.sme.8.6.6
tftp-server flash://cucme-mlpp
tftp-server flash:apps42.9-3-1ES13.sbn
tftp-server flash:cnu42.9-3-1ES13.sbn
tftp-server flash:cvm42sip.9-3-1ES13.sbn
tftp-server flash:dsp42.9-3-1ES13.sbn
tftp-server flash:spa50x-30x-7-5-5.bin
tftp-server flash:/its
Carlo Poggiarelli Thu, 03/06/2014 - 09:00
Hi.
When you add a new register profile, remember to issue create profile under voice register global.
Than.. Have you configured correclty Authentication parameters on SPA Phone?
Please activate a debug voice register error and debug voice register evens and post the output.
Carlo
dangquangminh Thu, 03/06/2014 - 10:08
log into the console port. turn on those two debug commands. Unplug the phones and then plug in. Unfortunately, i got now debug messages.
SHould i copied some firmware files of the 502G into the router flash?
