RCC + Presence + CUCM Extension mobility w/ Intercom line
Answered Question
May 29th, 2012
Guys,
Do you have any idea if deploy device profile w/ intercom line:
RCC: working
OCS 2007, OCS Client wo plugin, Presence 8.5.x, CUCM 8.5.x (extension mobility)
RCC : not working
OCS2007, OCS Client wo plugin, Presence 8.5.x, CUCM 8.5.x (extension mobility + intercom line)
debuging/ error display:
presence ->
not authorize
multiple line with out primary line, (i already setting primary line in end user page)
ocs client->
cannot connect to phone system
RD
Correct Answer by Novriadi . about 5 years 22 hours ago
Hi Dani,
- When using EM, you don't need adding device in OCS tel uri configuration.
tel:XXXXXXXXX;phone-context=dialstring;partition=YourPartition
for example :
tel:604104441;phone-context=dialstring;partition=PT_Internal
- When your users log on to other PC, they must manually redefine tel uri configuration. then sign out - sign in OCS.
- When your users log in EM in other phone, they must sign out -sign in OCS.
Again, Intercom on EM and your RCC should work together.
Please rate this post if helpful
Novri
Overall Rating: 5 (1 ratings)
Correct Answer
Novriadi . Tue, 05/29/2012 - 21:11
Hi Dani,
for example :
Novri
panjwani80 Tue, 07/10/2012 - 03:31
Hi Guys,
I got a similar problem too. I have a RCC integration working fine between CUCM 8.6 and OCS R1 as long as EM profile has a primary line (line 1). As soon as I had second line on the phone in the same partition as the first line the integration breaks and OCS says "cannot connect to the phone system".  My line URI has no MAC address or partition configured. It looks like this:
tel:8001;phone-context=dialstring
Working setup
Line 1: 8001 in INTERNAL
Not working setup
Line 2: 9999 in INTERNAL  (this line is just to collect after hours voicemail and will not be used make or receive calls)
Any help would be much appreciated
Aamir
