Warning message
Phone type Edge 95 MXP not found in CM8.6
Answered Question
May 29th, 2012
Hi all,
I'm trying to add new Device Phone in call manager 8.6
However, I can't find the Edge 95 MXP phone type.
Do I have to upload any firmware or choose other similar phone type??
Sam
Correct Answer by Amlesh Sengar about 5 years 2 months ago
Hi Sam,
  The mxp units can be registered to cucm as third party (basic) endpoints.
Please find the steps to register mxp.
Configure sip settings on mxp such as sip uri and proxy address.
1. Sip Mode: on
2. SIP Uri:    [email protected] of cucm   eg: [email protected]
3. Server Discovery : manual
4. Server Address:  ip address of cucm.
5.  Server Type: cisco
6.   Transport: let it be auto however incase that did not work, change to udp.
7.  TLs: off
8:  Sip authentication user name:  user you have created on cucm  eg  9011 or amlesh
9.  Password:  use same password configured while creating user 9011 or amlesh
CUCM config:
1.  Select third party basic profile.
2.  add mac address of mxp endpoint.
3.  select proper sip profile, phone templates etc.
4.  under digest user and owner user id select the same user eg: 9011 or amlesh
5.  save the configuration and assign same DN that we used in sip uri settings on mxp.
6.  Also associate mxp device to user using device association pane on cucm.
Please let me know if these work for you. I have tried this in my lab and that works.
Amlesh
Correct Answer by mubakhta about 5 years 2 months ago
Hi Sam,
Unfortunately MXP endpoints are still not supported to be registered to the CUCM. The support is only available for C series and Ex series devices as of now. You can check the release notes of the MXP software for any updates in the future.
Mubashshir Akhtar
Overall Rating: 5 (3 ratings)
Correct Answer
mubakhta Tue, 05/29/2012 - 03:15
  • Silver, 250 points or more
Hi Sam,
Mubashshir Akhtar
Correct Answer
Amlesh Sengar Thu, 05/31/2012 - 21:20
  • Cisco Employee,
Hi Sam,
1. Sip Mode: on
7.  TLs: off
CUCM config:
Amlesh
varungulati Thu, 01/29/2015 - 07:52
HI .. My understanding is .. MXP 95 comes with Multisite License ..
Does the multisite feature work fine when registered with CUCM as 3rd party end point .. ??
Just want to confirm , technically it should work .
Wayne DeNardi Thu, 01/29/2015 - 16:03
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 TelePresence
Hi Varun,
Rather than adding a question to an extremely old, answered thread, on a different topic, it would be better to post your new query as a new discussion.
But, as a quick answer to your question, no, the MXP 95 does not necessarily come with the Multisite Licence, unless it was ordered that way.
If you have a Multisite Licence on your device you will be able to see it listed on the System Status / System Information page on the Web Interface, it'll show "Multisite option  True".
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Volzhenin Dmitriy Sun, 06/28/2015 - 21:42
Hi, Perry.
How can I make a call from the MXP?
What  the profile of the settings you used to?
Related Content
