License IVR Ports.
Answered Question
May 29th, 2012
Hi NetPro
I have a questions for IVR ports and upgrade processes.
When upgrade de IPCC 4.X to UCCX 8.5 Premium, the IVR ports license it's a part number or this port is extracted from DMA Tool?
I see the IPCC DMA tool not export any license.. or not?
Kind Regards.
Correct Answer by anchoudh about 5 years 2 months ago
Hi Javier,
You need to provide your UCCX 7.x license as part of the UCRS 4.x to UCCX 7.0 upgrade (you need to provide the path of the UCCX 7.x license during restoring the DMT bacup of 4.x system) using the DMA tool.
DMA tool will not export any licenses as part of the upgrade.
http://www.cisco.com/web/software/282467017/23664/UCCX_DataMigrationTool_Guide_405x-701.pdf
(refer page 27)
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/installation/guide/uccx70ig.pdf
And again when you perform W1 (Windows to linux) upgrade from 7.x to 8.5, on 8.5 you need to have the UCCX license based on your license MAC of the hardware.
www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/e...
You can also contact [email protected] for further details.
And for your part number queries you can open a case with Partner Helpline team,
please use www.cisco.com/go/ph to do so.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
Overall Rating: 5 (1 ratings)
Correct Answer
anchoudh Tue, 05/29/2012 - 08:47
  • Red, 2250 points or more
Hi Javier,
(refer page 27)
Hope it helps.
Anand
jmecklenburg Tue, 05/29/2012 - 10:58
Thanks for you answer!
In the BOM for the upgrade the IVR port is a unique part-number?
Kind Regards.
Related Content
