Warning message
get digits microapp
May 29th, 2012
I have a get digit microapp in CVP 8.5 and icm 8.52.  My configuration parameters are as follows:
1,7,Y,3,4,1,1,Y,Y,#
my prompt is "Please enter your account number, if you do not know your account number press *."
If someone presses *, then the call will exit out of the X branch of the network vru script node and I have a custom prompt that says please make a selection.  I have tried to invoke some logic before playing the make selection prompt so that if they had entered * then continue to process the call without playing the prompt.  However, the check to see if they entered * returns false and it looks like it does not realize that a * was entered.
Has anyone encountered this before and what has been done to program around it, thanks.
I'll have a look at my previous scripts, but in general, I try to avoid this old style of combining data entry and menu selection - which is what you are doing.
I always try to convince the customer that the modern way is to split this up.
1. If you know your 7 digit account number, press 1. If not, press 2.
2. Please enter your 7 digit account number.
(I'm guessing that you have 7 digit account numbers because of the 1,7 in the GD.)
I love it when I can fix the min=max because then they don't have to enter the data termination char (#).
If it's possible, consider this approach.
Geoff
Related Content
