debug commands in cisco ACS 5.3
May 30th, 2012
I'm troublshooting a user authentication issue and I want to run a debug command in the cli.
Is there any command where i can see information about what info gets into the ACS?
Jatin Katyal Wed, 06/06/2012 - 18:44
  • Cisco Employee,
Here you go:
acs/admin# acs-config
Escape character is CNTL/D.
Username: ACS-GUI-USERNAME
Password: ACS-GUI-PASSWORD
You may run the below listed debugs commands for users in internal store and users in external store.
acs/admin(config-acs)# debug-log runtime level debug
acs/admin(config-acs)# debug-adclient enable
Now you can test few authentications so that we can have logs generated for that client.
After that you may check the live logs on the ACS by using below listed commands:
show acs-logs details  --> Show you all the available logs files
acs/admin# show acs-logs filename acsRuntime.log ---> You may see logs for any specific file.
Hope this hepls.
Jatin
Do rate helpful posts-
Related Content
