Hardware Recommendation
May 30th, 2012
Hello All
which will be an ideal model of router to support VPN
  • connectivity to 35 branch office
  • Bandwidth 10MB
  • GRE over IPSEC
  • 2 Internet Provider Connection
which will be ideal model of access switch to support
  • QOS
  • 40 users connectivity
  • POE
thanks
Marwan ALshawi Wed, 05/30/2012 - 03:43
Hi Joseph,
Cisco routers ISR G2 can be a good option for your requirements such as 2921 or 2951
however the best option ( but more expensive ) is Cisco ASR1000 as ASR can provide hardware and/or software redundancy aka inbox redundancy and in your case you are terminating two Internet links and connecting to 35 remote site to this router making high availability important eleemnt
unless you use two ISRs instead of one as edge routers and each Internet link terminate to one ISR and they can work in active/standby for VPN
switches
you can use any of the options below:
2960 ( stackable )
3560
3750 ( stackable )
please note that you could use Cisco ISR G2 with etherswitch model in the router itself as an option as well ! that provide:
16, 24, and 48 ports of GE or FE LAN, Local line-rate, Layer 2/3 switching, Same  feature set and roadmap as the latest Catalyst 3560-X/2960-S switches ( no POE+ "30w")
hope this help
Joseph W. Doherty Wed, 05/30/2012 - 16:44
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
For 10 Mbps router, 890 or 1921 should do although beside two Provider Connections, you didn't mention what media to support or what's needed for inside facing.
For a switch, 10/100 or 10/100/1000?  Uplinks?  How much POE per port and total?
nkarthikeyan Sun, 06/10/2012 - 01:40
Cisco 2921 router can be used for GRE over IPSec for accomadating 10 MB dual links
3560E-48PD-SF (PoE) can be used as an access switch
Related Content
