2 VPN Tunnels between 2 devices on separate links
Answered Question
May 30th, 2012
I have a 2811 connected to two different ISPs, implying I have 2 separate interfaces for both links. I initially setup a VPN tunnel to a 3rd party remote site on one of the links/interfaces. I am now required to setup an additonal VPN tunnel to the same remote site on the other interface/link. When I finish the config and run tests, I get an error saying that the crypto map is not applied on the correct interface and that the peer is being routed through a non-crypto map interface.
One thing I would like to know is if it is possible to configure the router to establish these two tunnels on the different links/interfaces to the same peer. Please note that the first VPN tunnel is still active, but the other one has just refused to come up. Please see the snippets of my router config below:
crypto ipsec transform-set ABCD esp-3des esp-md5-hmac
crypto isakmp policy 4
encr 3des
hash md5
authentication pre-share
group 5
crypto isakmp policy 5
encr 3des
group 2
crypto isakmp policy 6
encr 3des
group 2
crypto isakmp key 123key address x.x.130.130
crypto map SDM_CMAP_1 3 ipsec-isakmp
description VPN Tunnel to ABCD on x.x.130.130
set peer x.x.130.130
set transform-set ABCD
set pfs group5
match address ABCD
crypto map SDM_CMAP_2 1 ipsec-isakmp
description description PROD VPN Tunnel to ABCD
set pfs group5
match address ABCD_PROD
interface FastEthernet0/1
description ISP1 WAN INTERFACE$ETH-WAN$
ip address a.a.42.66 255.255.255.252
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
auto discovery qos
interface FastEthernet0/2/0
description ISP2_WAN_INTERFACE
ip address y.y.12.94 255.255.255.192
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
auto discovery qos
ip access-list extended ABCD
permit ip host 172.30.50.2 host x.x.130.138
ip access-list extended ABCD_PROD
permit ip host 172.19.205.31 host x.x.130.134
ip route 0.0.0.0 0.0.0.0 a.a.42.65
So its the tunnel running on ISP1 that is fine while the tunnel on ISP2 is not coming up.
While pasting this though, I just realized there is no default route for ISP2, could this be the problem and would adding another default route not create some sort of loop?
Femi
Correct Answer by Marcin Latosiewicz about 4 years 7 months ago
Femi,
You don't NEED to put both ISPs into VRF, uless I'm not seeing something it's not require in your case.
But anways for ipsec config check Nico's cheat sheet:
https://supportforums.cisco.com/docs/DOC-13524
Pay special attention around keyrings.
You will notice that keyrings are defined per front VRF.
Also note that "vrf" statment in isakmp profile is indicating where the clear text packets are, typically this should be same VRF as your LAN interface.
HTH,
Marcin
Overall Rating: 5 (1 ratings)
Marcin Latosiewicz Wed, 05/30/2012 - 05:24
Femi,
I don't want to overload you with information, but what we typically do in scenarios like this is to use separete VRFs for each ISP (the primary ISP can still be in global VRF).
I.e. you would have second WAN ISP in a separate VRF, this would allow you to also have a default route specific to that VRF/ISP.
Also if both sides are Cisco, I'd highly recommand using VTI solution rather than crypto maps - crypto maps are legacy configuration we're advising people to move away from them wenever possible.
M.
femi.agboade Wed, 05/30/2012 - 05:41
Hello Marcin,
Thanks for the feedback.
So i quickly went online to check what VRF meant, not familiar with the term or how it works. I am willing to try it out, if you can just give me some pointers on what to do. An example config would be ideal.
As regards VTI, not sure how this works as well but will explore same. Moreover, we will be introducing an ASA on the network to handle all firewalling and VPN config setup soon.
So please help with a sample config to handle the VRF suggestion.
Femi
femi.agboade Fri, 06/01/2012 - 04:25
Hello Marcin,
I have tried 2 different VRF sample configs but none has worked. The one that seemed closest to work is stated below:
ip vrf NI1
rd 100:1
route-target export 100:1
route-target import 100:1
ip vrf NI2
rd 101:1
route-target export 101:1
route-target import 101:1
crypto keyring NI1
  pre-shared-key address 1.58.130.130 key xxxxx
crypto keyring NI2
encr 3des
hash md5
group 5
encr 3des
group 2
encr 3des
group 2
crypto isakmp profile NI1
vrf NI1
keyring NI1
match identity address 1.58.130.130 255.255.255.255
crypto isakmp profile NI2
vrf NI2
keyring NI2
crypto ipsec transform-set NI esp-3des esp-md5-hmac
ip access-list extended NI1
permit ip host 172.30.50.2 host 1.58.130.138
ip access-list extended NI2
permit ip host 172.19.205.31 host 1.58.130.134
crypto map SDM_CMAP_1 1 ipsec-isakmp
description VPN Tunnel to NI1
set peer 1.58.130.130
set transform-set NI
set pfs group5
match address NI1
description PROD VPN Tunnel to NI2
set pfs group5
match address NI2
ip address 6.173.42.66 255.255.255.252
ip address 8.248.12.94 255.255.255.192
ip route 0.0.0.0 0.0.0.0 62.173.42.65
ip route 1.58.130.130 255.255.255.255 6.173.42.65
ip route 1.58.130.130 255.255.255.255 8.248.12.65
ip route vrf NI1 1.58.130.138 255.255.255.255 6.173.42.65 global
ip route vrf NI2 1.58.130.134 255.255.255.255 8.248.12.65 global
Note, i still have the default route set, without it, my internet users on the LAN segment have no internet access.
Can you help review and point out where i may be going off?
Thanks.
Femi
Correct Answer
Marcin Latosiewicz Fri, 06/01/2012 - 04:51
Femi,
HTH,
Marcin
femi.agboade Fri, 06/01/2012 - 05:15
Hello Marcin,
You say I dont need to put both ISPs into VRF, what do you reckon I do? Could you take a look at this link below, I just posted this today after I didnt make any progress still:
https://supportforums.cisco.com/message/3649920#3649920
Thanks for the link to the cheat sheet, I had read through and its one of the references I used for the commands I stated above. Will go through again and compare with what I posted.
Femi
femi.agboade Fri, 06/01/2012 - 11:35
Hello Marcin,
When you said I didnt need to put both ISPs into VRF, i assume you meant that I only needed to put on f the ISPs into VRF, specifically the other ISP I was trying to establish a new VPN connection over?
I did read the cheat sheet thoroughly and also went through some other documents. However, I still cound not get out of the router as the router kept complaining about routing issues:
1. The peer must be routed through the crypto map interface. The following peer(s) are  routed through non-crypto map interface - a.b.130.130
2. The tunnel traffic destination must be routed through the crypto map interface. The following destinations are routed through non-crypto map interface - a.b.130.134
Below is the config I applied but I didnt get traffic out of the router still to even attempt to establish a connection:
ip vrf PROD_INTCON
rd 100:1
ip vrf ISP2
rd 101:1
crypto keyring NI2-keyring vrf ISP2
  pre-shared-key address a.b.130.130 key xxxxx
encr 3des
hash md5
group 5
encr 3des
group 2
encr 3des
group 2
crypto isakmp profile NI2-profile
vrf PROD_INTCON
keyring NI2-keyring
match identity address a.b.130.130 255.255.255.255 ISP2
isakmp authorization list default
crypto ipsec transform-set NI2set esp-3des esp-md5-hmac
set peer a.b.130.130
set transform-set NI2set
set pfs group5
set isakmp-profile NI2-profile
match address NI2_ACL
reverse-route
ip vrf forwarding ISP2
ip address z.y.12.94 255.255.255.192
interface FastEthernet0/2/1.603
description PROD_INTCON_ZONE
encapsulation dot1Q 603
ip vrf forwarding PROD_INTCON
ip address 172.19.205.1 255.255.255.0
ip flow ingress
ip nat inside
ip route vrf ISP2 0.0.0.0 0.0.0.0 z.y.12.65
ip route vrf PROD_INTCON a.b.130.134 255.255.255.255 FastEthernet0/2/0 z.y.12.65
ip access-list extended NI2_ACL
permit ip host 172.19.205.31 host a.b.130.134
femi.agboade Wed, 06/13/2012 - 10:29
Hello Marcin,
This is just to confirm that my last post config worked just fine. The problem was some security setting which didnt allow me generate packets with source IP from the router but the moment i setup the system with that source IP and attempted to connect to the destination host, the tunnel got formed.
Thanks for all the help, IP VRF does sound a very inetersting technology to work with.
Cheers.
