Warning message
Access-list with DHCP
May 30th, 2012
Hello Cisco support community,
I have a question regarding ACL with DHCP:
I have cisco 881 routers:
     - VLAN 1 (FastEthernet 0, 1, 2 and 3): IP address 172.20.0.1/16
     - FastEthernet 4 (connected to another network): IP address receivede from a DHCP server.
These router will be installed on different sites where I don't have access to the DHCP server: I don't know the IP address that FA4 will receive.
I want to make an inbound ACL to allow access to 1 host in the FA4 network to a specific port.
interface fa 4
ip access-group  FILTER in
ip access-list FILTER
permit tcp host [host IP] [IP FA4] eq [port]
How can I do that kind of ACL if I don't know the IP address of FA4 in advance ?
Thank you !
Nicolas
Overall Rating: 5 (1 ratings)
johnlloyd_13 Sun, 06/03/2012 - 08:55
  • Blue, 1500 points or more
hi nicolas,
if FE4 is receving dynamic IP from DHCP, you could put your ACL under VLAN 1 SVI instead.
Jeff Van Houten Sun, 06/03/2012 - 10:09
  • Silver, 250 points or more
Why not just put the acl on the server itself? Windows and Linux both have port filters you could activate and allow only the traffic you specify inbound.
Tagir Temirgaliyev Sun, 06/03/2012 - 22:01
you will need to enable DHCP to get address
permit udp any any eq 67
permit udp any any eq 68
permit tcp host [host IP] 172.20.0.0 0.0.255.255 eq [port]
this will enable to get dhcp address
and comunication from [host IP] to your network 172.20.0.0 0.0.255.255
dont forget to rate post if it helps
