ACS appliance failover( High Availibility) documentation
I have to configure Cisco ACS for Active/Passive role. I am looking for some documentation on that on cisco website but can not find it.
Can anyone suggest me proper best practice documentation ?
Thank you,
Nilay
mauzamor
Hi there,
The ACS doesn't work like an ASA where you can have one active and the other standby. What you can do is to have one primary and another as the secondary, where depending on your TACACS+/Radius commands the authentication server role will change, for example:
tacacs-server host 10.0.0.1 key xxx
tacacs-server host 20.0.0.1 key xxx
This configuration means that the router will try to contact 10.0.0.1 always, but if this server goes down, the router will try to contact 20.0.0.1 until the 10.0.0.1 is up again.
So as you can see the ACS servers doesn't have control about which will be the active server, only which is the primary and which is the secondary (primary and secondary is important because you configure the settings in the primary and this one replicates those changes to the secondary).
Documentation:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.2/user/guide/admin_operations.html#wp1066095
Hello Nilay.
Mauricio is right. To expand his answer, if you have several  ACS appliances only one of them is primary and all the other ones are  secondary.
"Primary" and "secondary" concepts are different from "active" and "standby" concepts. All ACS are "active".
The  switch configuration tells the switch which ACS to talk to. It can be  one, two, three, any number of ACS. Also if there are more than one ACS,  the switch configuration gives the preference to the first ACS declared  in the configuration. Only if the first ACS doesn't respond at all  then the switch will try to talk to the second ACS declared. Only if the  second ACS doesn't respond at all then the switch will try to talk to  the third ACS and so on.
here's an example of switch configuration with three ACS
radius-server host 192.168.1.10 key MYPASSWORD
radius-server host 192.168.1.11 key MYPASSWORD
radius-server host 192.168.1.12 key MYPASSWORD
radius-server vsa send authentication
aaa new-model
aaa group server radius ACS
server 192.168.1.10
server 192.168.1.11
server 192.168.1.12
aaa authentication dot1x default group ACS
aaa authorization network default group ACS
aaa accounting dot1x default start-stop group ACS
I configured distributed deployment explained in above document and it works fire. Thank you for your help.
-Nilay
