Warning message
Backup Strategy of Cisco Voice Servers
May 30th, 2012
Hey Everyone,
My boss mentioned to me that he wants to start making backup's of our cisco voice enviornment.  Currently we have 4 servers.
1) UCCX
2) Unity
3) UCMPU
4) UCMSUB
All of these servers are build with a RAID 1 mirror.  He mentioned that typically people will pull one hard drive to keep as a backup, and then rebuild the mirror with a new blank hard drive.
Is this something anyone can speak to?  It sounds pretty straightforward, but I want to find out if there is a typical procedure you would follow for this.  I've done similar things with Windows servers, but never in a cisco enviornment.
Overall Rating: 5 (1 ratings)
Jaime Valencia Wed, 05/30/2012 - 11:25
  • Cisco Employee,
  • Hall of Fame,
    2011
Just an FYI, we do not support that as a backup method. We only support swapping HDDs in case of failure.
Otherwise, just use the backup method for each product that we provide.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Wed, 05/30/2012 - 11:30
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
I'll just add a reference to the great tips from my friend Java (+5 "J") Bosses always
want to see these things in writing
Removing Hard Drives
Cisco only supports replacing failed hard drives. Cisco does not support  drive pulling/swapping as a method of fast upgrade reversion, restore,  or server recovery. For information on replacing a failed hard drive,  refer to the Troubleshooting Guide for Cisco Unified Communications Manager.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713.html#wp1600579
So...DRS is your best friend here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/7_1_2/drsag712.html
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
