Dynamic multipoint vpn network
May 30th, 2012
Hi team we have 6 locations connected through the dynamic multipoint pvn network, we are using this network for voip phones, some this whole vpn network goes down, and than come back automatically after some time, i was logged in to hub router and found some errors, thse errors are as follow, can any body suggest what is the cause for those
000176: May 30 09:44:29.763 PCTime: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd I
PSEC packet has invalid spi for destaddr=hub wap ip, prot=50, spi=0xAEB1655C(
2930861404), srcaddr=remote 2 wan ip
000177: May 30 09:45:33.149 PCTime: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd I
000178: May 30 09:46:39.141 PCTime: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd I
i replaced all IP addreses with there locations, i have those errors form almst all locations
regards
krishan saran
Mohammad Alhyari Sat, 06/02/2012 - 12:23
  • Bronze, 100 points or more
HI Krishan ,
thanks for posting this here .
this may indicate a syhcronization issue between the two peers , that one peer is still using an old SA that has been deleted on the other peer , thus when receiving the IPSEC packet on the device it will report that there is no IPSEC sa active for this connection .
The received IPsec packet specifies a Security Parameters Index (SPI) that does not exist in the security associations database (SADB). This could be a temporary condition due to:
  • Slight differences in the aging of security associations (SAs) between the IPsec peers
  • The local SAs having been cleared
  • Incorrect packets sent by the IPsec peer
do you have crypto isakmp keepalives enabled on the devices ?
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t7/feature/guide/gtdpmo.html
on the other hand you need to check why the VPN tunnels are going down ?
Debug crypto isakmp
debug crypto ipsec
hope that this helps.
cheers.
Mohammad.
krishan.saran Sun, 06/03/2012 - 00:27
Thanks mohamed, thats make sence, i will check the timers in all routers and update back,
Krishan Saran
Uniconnect Networks Inc.
Ph. 604-235-1965
Cell 778-840-5961
www.uniconnectnetworks.com
Related Content
