Warning message
Nexus 3048 QoS policing?
May 30th, 2012
Just wondering if anyone may know a way of policing traffic on the Nexus 3k platform? I can't find a reference to say policing/shaping is supported...
Overall Rating: 4.5 (2 ratings)
nkarpysh Wed, 05/30/2012 - 17:37
  • Cisco Employee,
Afaik no. Nexus 3k is considered as Low Latency Queueing switch and shaping and policing triggers the queueing (if we talk about egress one) which does not fit in low latency theory as per developers.
The way to configure QoS is to split traffic into queues and limit bandwidth for those.
E.G.
N3k-1(config)# class-map type qos QUE_class
N3k-1(config-cmap-qos)# match cos 0-7
2)      Create a queuing policy-map:
N3k-1(config-cmap-qos)# policy-map type queuing QUE_policy
3)      Assign a class to this policy map:
N3k-1(config-pmap-que)# class type queuing QUE_class
4)      Set bandwidth percentage to 5%, which would be 50Mb on a 1G
interface
N3k-1(config-pmap-c-que)# bandwidth percent 5
5)      Set the bandwidth on the class-default to 0%:
N3k-1(config-pmap-que)# class type queuing class-default
N3k-1(config-pmap-c-que)# bandwidth percent 0
6)      Apply this policy-map to an interface:
N3k-1(config)# int e1/1
N3k-1(config-if)# service-policy type queuing output QUE_policy
N3k-1(config-if)# service-policy input QUE_policy
Here is what your interface should look like:
N3k-1# show policy-map int e1/1 in
Global statistics status :   disabled
Ethernet1/1
  Service-policy (qos) input:   QUE_policy
    policy statistics status:   disabled
    Class-map (qos):   QUE_class (match-all)
      Match: cos 0-7
    Class-map (qos):   class-default (match-any)
      Match: any
      set qos-group 0
N3k-1# show policy-map int e1/1 out
Ethernet1/1
  Service-policy (queuing) output:   QUE_policy
    Class-map (queuing):   QUE_class (match-any)
      bandwidth percent 5
    Class-map (queuing):   class-default (match-any)
      Match: qos-group 0
      bandwidth percent 0
Nik
martynworthingt... Wed, 05/30/2012 - 22:28
Hi Nik,
What do you think of the config below?  Do you think this would work for limiting the traffic to/from a specific network?  (It's just an example.)
ip access-list My_ACL
  10 permit ip 192.168.1.0/24 any
  20 permit ip any 192.168.1.0/24
class-map type qos match-all My_ACL_QoS_Class
  match access-group name My_ACL
policy-map type qos QoS_Classify_Policy
  class My_ACL_QoS_Class
    set qos-group 1
class-map type queueing My_Q_QoS_Class
  match qos-group 1
policy-map type queueing My_Q_QoS_Policy
  class type queueing My_Q_QoS_Class
    bandwidth percent 10
  class type network-qos class-default
int eth1/1
service-policy type queuing output My_Q_QoS_Policy
service-policy input My_Q_QoS_Policy
nkarpysh Wed, 05/30/2012 - 22:38
  • Cisco Employee,
That should work. Though policy QoS_Classify_Policy should be applied to interface to do inital marking or you just avoid using it and match ACL in class  My_Q_QoS_Class instead of qos-group.
Nik
