05-30-2012 10:15 PM - edited 03-10-2019 05:41 AM
Could anyone tell me why vs0 is showing red?
Overall Health Status Green
Health Status for Failed Applications Green
Health Status for Signature Updates Green
Health Status for License Key Expiration Green
Health Status for Running in Bypass Mode Green
Health Status for Interfaces Being Down Green
Health Status for the Inspection Load Green
Health Status for the Time Since Last Event Retrieval Green
Health Status for the Number of Missed Packets Green
Health Status for the Memory Usage Not Enabled
Health Status for Global Correlation Not Enabled
Health Status for Network Participation Not Enabled
Security Status for Virtual Sensor vs0 Red
05-31-2012 08:15 AM
Hi Tariq,
Someone else can correct me if I'm wrong but I believe that this means you had a high severity event trigger in the last 5 minutes. You should check your events on the sensor when this happens to see what was triggered. The condition should clear on it's own provided you don't have a steady stream of high severity alerts coming in.
Jon.
06-01-2012 09:53 AM
You are correct Jon
06-02-2012 01:04 AM
you are 100% correct Jon. Thanks for you reply.
