Warning message
Radius over Sito-to-Site VPN
May 31st, 2012
Hello everybody,
I have a Sito-to-Site VPN between two ASA 5540 outside interfaces.
I'm trying to configure ssh radius authentication on one of them but the Radius server is located behind the other ASA.
When I try to connect to this ASA outside interface using my radius credentials, the communication to the radius server goes in timeout.
It seems that the ASA doesn't use the crypto map to route the request to the Radius server.
Can anyone help me.
This is the radius config on the ASA:
aaa-server RADIUS protocol radius
accounting-mode simultaneous
max-failed-attempts 5
aaa-server RADIUS (outside) host radius01
key *****
aaa authentication ssh console RADIUS LOCAL
Paolo
Overall Rating: 5 (1 ratings)
Jennifer Halim Thu, 05/31/2012 - 06:12
  • Cisco Employee,
Since you would like your radius authentication to go over the VPN tunnel, then you would need to specify the inside interface, instead of outside interface. That would source the radius request from the inside interface which I believe the subnet should be part of the crypto ACL. Otherwise, if it's not part of the crypto ACL, you can add that subnet so it goes over the vpn tunnel.
aaa-server RADIUS (inside) host radius01
Badriddin Gulyaev Tue, 06/11/2013 - 06:12
I have the same problem, and i tried to put inside interface instead outside but still asa wont to connect to RADIUS.
Jatin Katyal Tue, 06/11/2013 - 07:17
  • Cisco Employee,
Are you able to ping the radius server sourcing inside interface?
ping inside radius-ip-address
Please provide the debugs from the ASA
debug radius
debug aaa authen
run the test command:
test aaa authentication RADIUS host radius-server-ip
username:xxxxx
password:xxxxx
Are you seeing any hits on the radius side?
Jatin Katyal
- Do rate helpful posts -
Badriddin Gulyaev Wed, 06/12/2013 - 22:40
No i cannot ping from inside Interface Ip of my RADIUS
and this is the debug while testing
FMFB-KGT# radius mkreq: 0x17e
alloc_rip 0xd8d2bc08
    new request 0x17e --> 20 (0xd8d2bc08)
got user 'badriddin.g'
got password
add_req 0xd8d2bc08 session 0x17e id 20
RADIUS_REQUEST
radius.c: rad_mkpkt
RADIUS packet decode (authentication request)
Raw packet data (length = 69).....
01 14 00 45 46 07 34 5d d2 a3 a0 59 1e ff cc 15    |  ...EF.4]...Y....
2a 1b b8 91 01 0d 62 61 64 72 69 64 64 69 6e 2e    |  *.....badriddin.
67 02 12 a4 01 06 8e ab df 27 4a 51 9e dc 16 2d    |  g........'JQ...-
24 27 e3 04 06 c0 a8 06 65 05 06 00 00 00 0b 3d    |  $'......e......=
06 00 00 00 05                                     |  .....
Parsed packet data.....
Radius: Code = 1 (0x01)
Radius: Identifier = 20 (0x14)
Radius: Length = 69 (0x0045)
Radius: Vector: 4607345DD2A3A0591EFFCC152A1BB891
Radius: Type = 1 (0x01) User-Name
Radius: Length = 13 (0x0D)
Radius: Value (String) =
62 61 64 72 69 64 64 69 6e 2e 67                   |  badriddin.g
Radius: Type = 2 (0x02) User-Password
Radius: Length = 18 (0x12)
a4 01 06 8e ab df 27 4a 51 9e dc 16 2d 24 27 e3    |  ......'JQ...-$'.
Radius: Type = 4 (0x04) NAS-IP-Address
Radius: Length = 6 (0x06)
Radius: Value (IP Address) = 192.168.6.101 (0xC0A80665)
Radius: Type = 5 (0x05) NAS-Port
Radius: Value (Hex) = 0xB
Radius: Type = 61 (0x3D) NAS-Port-Type
Radius: Value (Hex) = 0x5
send pkt pdcsrv/1645
RADIUS_SENT:server response timeout
RADIUS_DELETE
remove_req 0xd8d2bc08 session 0x17e id 20
free_rip 0xd8d2bc08
radius: send queue empty
How to make it accessible to ping the remote side through crypto tunel?
a.crusius Mon, 07/29/2013 - 04:56
Try this:
management-access inside
This fixed the problem for me.
Related Content
