Warning message
Which Codecs are Supported on CUCM 8.5?
Answered Question
May 31st, 2012
Hello Community,
Can you please assist on the above question? Is g726 supported and if yes why such a high-bitrate codec is not set as default on the CUCM settings?
thanks in advance
Correct Answer by Chris Deren about 5 years 2 months ago
From Data sheet:
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6788/vcallcon/ps556/data_sheet_c78-652908.html
Codec support for automated bandwidth selection:  G.711 (mu-law and a-law), G.722, G.722.1, G.723.1, G.728, G.729A/B,  Global System for Mobile-Enhanced Full Rate (GSM-EFR), Global System for  Mobile-Full Rate (GSM-FR) Internet Low Bitrate Codec (iLBC), iSAC,  wideband audio (proprietary 16-bit resolution; 16-kHz sampled audio),  and Advanced Audio codec (AAC) for use with Cisco TelePresence devices
However the codec supported between devices is driven by what the endpoint supports.
Think of G726 as old technology hence little support.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Thu, 05/31/2012 - 14:18
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
From Data sheet:
HTH,
Chris
