CUCM 6.1(4a)SU2 Readme and Release notes
May 31st, 2012
I'm currently running CUCM 6.1(2).
Per TAC I need to get to CUCM 6.1(5)SU3 to address MOH issue.
CUCM 6.1(5)SU3 Readme and compatibility guides says I cannot directly upgrade, so I need interim version.
I found and downloaded CUCM 6.1(4a)SU2 ISO, but I can't for the life of me
find a Readme or Release notes for CUCM 6.1(4a)SU2 and specifically the chksum for the combined ISO download.
Any help finding Readme or Release notes for CUCM 6.1(4a)SU2 would be appreciated.
Tim
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 05/31/2012 - 17:13
  • Cisco Employee,
  • Hall of Fame,
    2011
go to downloads and add both files to your cart, then click on your cart and there should be a Readme link there with that info.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Fri, 06/01/2012 - 07:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Tim,
I'll just add a note to the rgeat tips from my friend Java (+5)
If you hover your browser over the Files listed on the software download page
before downloading you will see a window pop up with the read-me
3Use an md5sum utility to verify that the MD5 sum of the final file is correct.
The MD5 for this download is: 214efffb9c8eee3dfc5dfe6633d88ceb
http://www.cisco.com/web/software/282074295/29171/cucm-readme-614asu2.pdf
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
