CICP and XenApp / Xendesktop enviroment
Jun 1st, 2012
I wish to know is the CIPC is supported in XenApp / Xendesktop enviroment.
Any suggestion / reference will be appreciated.
Thanks Mario.
Jaime Valencia Fri, 06/01/2012 - 08:59
  • Cisco Employee,
  • Hall of Fame,
    2011
No, it's not. Such is explained in the RNs.
If you're going to deploy a VXi solution you need to use the VXC 4000
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
