C-series - Hide call history?
Answered Question
Jun 1st, 2012
Hi all,
Have a question regarding the call history function on C-series.
Is it possible to hide, remove, reset or to disable the call history?
Customer doesn't want others using the same conference room to view the call history/who they've been in contact with.
Thought about using a MCU as middle man, but would like to know if it's possible to do something on the codec instead.
//Johan
Correct Answer by Tomonori Taniguchi about 5 years 2 months ago
C-series Endpoint support startup script and you able to add your script with API that support by Endpoint.
Therefore if you shutdown/restart after finished the call or end of business day, then you can manage to delete the logs.
Step 1: Make"scripts.d" directory under /user (mkdir /user/scripts.d)
Step 2: Create startup file and first line must contain “#!/usr/bin/env tsh”.
Sample: script_delete_calllog
#!/usr/bin/env tsh
xCommand CallLog Clear
xCommand CallLog Recent Delete
xCommand CallLog Outgoing Delete
xCommand CallLog Received Delete
xCommand CallLog Missed Delete
xCommand CallLog Missed Dismiss
Adding the extra line between commands to give a break.
Step 3: Make file as executable by executing “chmod +x script” command on scripts.d folder.
Example:
[C90:/user/scripts.d] $ chmod +x script
  [C90:/user/scripts.d] $ ls -al
  total 8
  drwxr-xr-x 2 root root 1024 Feb 4 23:57 .
  drwxr-xr-x 8 root root 1024 Feb 4 23:50 ..
  -rwxr-xr-x 1 root root   78 Feb 4 23:06 script
  -rw-r--r-- 1 root root 5120 Feb 5 00:03 typescript\
Correct Answer by Teck Chye Tang about 5 years 2 months ago
I am afraid you are not able to hide or disable the call history.  But you can certainly delete them.
you can use the API command below to delete them.
    LogTag: <0..2147483647>
For example : xCommand CallLog Clear  - this will clear all the call history.
Maybe you can write a script that runs on a pre-determined time each day to clear the call history
Hope this is what you are asking.
Overall Rating: 5 (3 ratings)
Correct Answer
Teck Chye Tang Fri, 06/01/2012 - 08:43
  • Cisco Employee,
Correct Answer
Tomonori Taniguchi Sat, 06/02/2012 - 04:36
  • Cisco Employee,
#!/usr/bin/env tsh
Example:
  total 8
johan.alkarp Mon, 06/04/2012 - 04:23
Thanks to both of you for nice answers!
Follow up question:
Would it be possible to use a custom command from a persistant template from TMS to do this?
And how would that command be in that case
// Johan
Tomonori Taniguchi Mon, 06/04/2012 - 04:32
  • Cisco Employee,
Unfortunately Persistent settings with template if for configuring the endpoint with first register or boot up. Therefore won’t help to delete the logs on Endpoint.
Related Content
