Warning message
paolo bevilacqua Fri, 06/01/2012 - 09:21
  • Hall of Fame,
    Founding Member
Yes. Remember that you need DSP (PVDM2).
davidmejia Fri, 06/01/2012 - 13:54
Hi Paolo, Thanks for your help, for the DSPs do you recomend the PVDM2-32? do you think it would be enough?
Cody Link Fri, 06/01/2012 - 14:02
A PVDM2-32 will support 32 G711 streams so that would be more than enough for your 4FXO card.  A cheaper solution might be a PVDM2-8.
