VPN split tunneling question???????
Answered Question
Jun 1st, 2012
Hi All
Can somebody tell me what options I have, before I use ASA Split tunneling .Thanks
I dont want to  use the split tuneeling as last resorce.
thanks
Correct Answer by mikull.kiznozki about 5 years 1 month ago
we could also use a vpn filter to control the traffic flow as per acl's on your ipsec tunnel. that imo is the best way to control the traffic!
Overall Rating: 5 (1 ratings)
Julio Carvajal Fri, 06/01/2012 - 16:50
  • Purple, 4500 points or more
Hello Juan Carlos,
The thing is that as long as you do not use the Split tunneling feature all traffic will be tunneled.
So the options you have are:
1-Tunnel all traffic
2- Tunnel specific traffic (Split tunnel policy)
Julio
Javier Portuguez Fri, 06/01/2012 - 20:09
  • Red, 2250 points or more
In addition to the previous post you could also configure exlude-specified, which allows you to route all traffic thru the tunnel except for specific networks. A pretty common approach of this implementation is called "LOCAL LAN ACCESS".
Please let us know if you have any further questions.
Sent from Cisco Technical Support Android App
Correct Answer
mikull.kiznozki Sat, 06/02/2012 - 07:23
Javier Portuguez Sat, 06/02/2012 - 09:22
I agree with Mikull's post, the VPN filter is a powerful tool, to limit VPN access.
