VPN Info not showing up!
Jun 1st, 2012
I have successfully set up a pptp vpn from my new rv220w.  I have also successfully logged in using 2 seperate laptops and also my iPhone.  They all work great.   There is one issue.  When connected and I log into the router it does not show these laptops or iPhone as being connected to the vpn.  There is two spots that its supposed to show the page refreshes and shows nothing connected.  Is there a setting I am missing?
mikull.kiznozki Sat, 06/02/2012 - 22:21
how are you checking it? did u create a virtual template on the router?
did u try a sh ip int brief? if i am not mistaken, if you connect using pptp on a cisco router and have bootp for dhcp it will shop up as a virutal template interface in sh ip int brief for every client.
xnoaimx27 Mon, 06/04/2012 - 07:53
I am looking at this in two places.  On the summary dashboard page of the router it has a place for connected users vpn for pptp, quickvpn and ssl users.
There is also a page "VPN Client connection status"
Related Content
