Warning message
ASA 5505 VPN Can not connect clients
Jun 4th, 2012
I tried to search for an answer to this question but I couldn't find the answer.
I configured the VPN on the ASA, I can not  get a client to connect to the ASA  I've tried and search for an answer and I really need som help!
Any help is greatly appreciated.
: Saved
ASA Version 7.2(2)
hostname
domain-name
enable password
names
ddns update method
ddns both
interface Vlan1
nameif inside
security-level 100
ddns update hostname
ddns update
dhcp client update dns
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.0
ospf cost 10
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server
name-server
domain-name
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list EasyVPN_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list OUTSIDE_IN_ACL extended permit ip any any
access-list OUTSIDE_IN_ACL extended permit icmp any interface outside
access-list Remote-VPN_splitTunnelAcl standard permit any
access-list DefaultRAGroup_splitTunnelAcl standard permit any
access-list Bild_splitTunnelAcl standard permit any
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool TKK 192.168.1.200-192.168.1.220 mask 255.255.255.224
ip local pool VPN-Pool 192.168.254.1-192.168.254.10 mask 255.255.255.0
no failover
monitor-interface inside
monitor-interface outside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
nat (outside) 0 access-list outside_nat0_outbound
static (inside,inside) tcp interface 3389 access-list inside_nat_static
static (inside,inside) tcp interface ftp access-list inside_nat_static_2
static (outside,inside) x.x.x.x 192.168.1.0 netmask 255.255.255.255 dns
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group outside_access_in in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server value 192.168.1.253
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
client-firewall none
client-access-rule none
webvpn
  functions url-entry
  html-content-filter none
  homepage none
  keep-alive-ignore 4
  http-comp gzip
  filter none
  url-list none
  customization value DfltCustomization
  port-forward none
  port-forward-name value Application Access
  sso-server none
  deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission
to use any of the VPN features. Contact your IT administrator for more information
  svc none
  svc keep-installer installed
  svc keepalive none
  svc rekey time none
  svc rekey method none
  svc dpd-interval client none
  svc dpd-interval gateway none
  svc compression deflate
group-policy EasyVPN internal
group-policy EasyVPN attributes
split-tunnel-network-list value EasyVPN_splitTunnelAcl
default-domain value xxx.se
group-policy Remote-VPN internal
group-policy Remote-VPN attributes
split-tunnel-network-list value Remote-VPN_splitTunnelAcl
group-policy CiscoASA internal
group-policy CiscoASA attributes
dns-server value 192.168.1.253 x.x.x.x
vpn-tunnel-protocol IPSec webvpn
group-policy Bild internal
group-policy Bild attributes
split-tunnel-network-list value Bild_splitTunnelAcl
username User attributes
vpn-group-policy DfltGrpPolicy
username Bild password encrypted privilege 0
username Bild attributes
vpn-group-policy Bild
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set TRANS_ESP_DES_SHA esp-des esp-sha-hmac
crypto ipsec transform-set TRANS_ESP_DES_SHA mode transport
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 60 set pfs
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 80 set pfs
crypto dynamic-map outside_dyn_map 80 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 100 set pfs
crypto dynamic-map outside_dyn_map 100 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 120 set pfs
crypto dynamic-map outside_dyn_map 120 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 140 set pfs
crypto dynamic-map outside_dyn_map 140 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 160 set pfs
crypto dynamic-map outside_dyn_map 160 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 180 set pfs
crypto dynamic-map outside_dyn_map 180 set transform-set TRANS_ESP_DES_SHA
crypto dynamic-map outside_dyn_map 200 set pfs
crypto dynamic-map outside_dyn_map 200 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 220 set pfs
crypto dynamic-map outside_dyn_map 220 set transform-set ESP-DES-SHA
crypto dynamic-map inside_dyn_map 20 set pfs
crypto dynamic-map inside_dyn_map 20 set transform-set ESP-DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal  20
crypto isakmp ipsec-over-tcp port 10000
tunnel-group DefaultRAGroup general-attributes
address-pool vpn
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *
tunnel-group Bild type ipsec-ra
tunnel-group Bild general-attributes
address-pool TKK
default-group-policy Bild
tunnel-group Bild ipsec-attributes
pre-shared-key *
tunnel-group CiscoASA type ipsec-ra
tunnel-group CiscoASA general-attributes
address-pool vpn
default-group-policy CiscoASA
tunnel-group CiscoASA ipsec-attributes
pre-shared-key *
tunnel-group EasyVPN type ipsec-ra
tunnel-group EasyVPN general-attributes
address-pool vpn
default-group-policy EasyVPN
tunnel-group EasyVPN ipsec-attributes
pre-shared-key *
tunnel-group Remote-VPN type ipsec-ra
tunnel-group Remote-VPN general-attributes
address-pool VPN-Pool
default-group-policy Remote-VPN
tunnel-group Remote-VPN ipsec-attributes
pre-shared-key *
class-map global-class
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global-policy
class global-class
  inspect ftp
  inspect icmp
  inspect pptp
service-policy global-policy global
prompt hostname context
Cryptochecksum:8cdda33b1993ba7bb33db88d996e939c
: end
Jennifer Halim Mon, 06/04/2012 - 05:19
  • Cisco Employee,
Please kindly add the following isakmp policy:
crypto isakmp policy 5
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 8
encryption 3des
hash md5
group 2
lifetime 86400
If you don't have 3DES/AES license, you can obtain the activation key from the following:
https://tools.cisco.com/SWIFT/LicensingUI/loadDemoLicensee?FormId=139
rizwanr74 Mon, 06/04/2012 - 08:27
  • Gold, 750 points or more
Hi Fredrik,
I see your acl "outside_nat0_outbound" set on inside interface for no nat, but I do not see, the acl is being defined anywhere on your config.
I also strongly recommand create your vpn-pool to be different subnet rather being as same as your inside ip of your ASA.
so, let assume your vpn pool is 192.168.255.1-254/24
so, your no-nat for inside will look like this below.
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.255.0 255.255.255.0
Let me know, if this helps.
thanks
