Issue with vPC on Nk5 (Type-2 consistency status)
Jun 4th, 2012
Hi guys
i got an error during configuration of vPC between thow Nk5548UP swithes.
Please find attached configuration og both switches.
I cant see any missmatch in configuraiton
I also see following error under vPC status:
Type-2 consistency reason       : QoSMgr Qos configuration incompatible
Please advice!
/S
Ivan Shirshin Mon, 06/04/2012 - 04:11
Type-2 error like this should refer to a configuration mismatch. Checking the outputs, there is a mismatch in QoS setup:
SW-A-SITE-NK5-01# sh vpc consistency-parameters global
    Legend:
        Type 1 : vPC will be suspended in case of mismatch
Name                        Type  Local Value            Peer Value
QoS                         2     ([], [3], [], [], [],            ([], [], [], [], [],
Note that beginning with Cisco NX-OS Release 5.0(2)N1(1), QoS parameters have been downgraded from Type 1 to Type 2, so they don't affect the link "up" status.
Looking at the configurations, there do seem to be differencies in QoS part.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
vucko-sanel Mon, 06/04/2012 - 04:21
how should i resolve this issue Ivan now Ivan?
what about second errror i got during vpc configuration ...
SW-A-SITE-NK5-02# sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 5
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : failed
vPC role                        : secondary
Number of vPCs configured       : 1
Peer Gateway                    : Disabled
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
vPC Peer-link status
vucko-sanel Mon, 06/04/2012 - 04:39
i managed to solve the issue with QoSMgr Qos configuration incompatible.
Of some reasone some QoS configuration were mising on SW-A-SITE-NK5-02 switch.
But i still have issue wth Type-2 consistency statu failed, which i am not able to figure out ...
Ivan Shirshin Mon, 06/04/2012 - 04:44
Could you send the fresh output of "sh vpc consistency-parameters global ", please?
Ivan Shirshin Mon, 06/04/2012 - 04:42
The "Type-2 consistency status       : failed" indicates consistency status (failed => inconsistent/mismatching), while "Type-2 consistency reason       : QoSMgr Qos configuration incompatible" indicates in which part of the vpc setup is this inconsistency detected at (QoS in your case)..
I have checked the configuration differencies and I see the following QoS configured on NK5-01 but missing on NK5-02:
policy-map type network-qos fcoe-ny-default
  class type network-qos class-fcoe
    pause no-drop
    mtu 2158
  class type network-qos class-default
    mtu 9216
    multicast-optimize
system qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type qos input fcoe-default-in-policy
Could you make the QoS configuration identical (delete from NK5-1 or configure on NK5-2) and check if that fixed the inconsistency?
Kind Regards,
Ivan
vucko-sanel Mon, 06/04/2012 - 04:46
like i wrote previously, the issue was with missing QoS paramenter on sw2
but could u help med with other error message i have on vpc configuration .. ?
SW-A-SITE-NK5-02# sh vpc brief
Legend:
vPC domain id                   : 5
Type-2 consistency reason       : VTP type-2 configuration incompatible
id   Port   Status Active vlans
1    Po1    up     1,7,16-17,48,61,63,66,69,73-74,76,78,80-82,86,90,9
                   4,96,150-151,160-161,200,203,210,300-307,400,403-4
                   10,412-413,418-421,423-430,434,437-443,445-451,460
                   -462,510,557-560,562-570,576-583,666,700-707,709-7
                   17,851,853-856,999,3000
vPC status
id     Port        Status Consistency Reason                     Active vlans
15     Po15        up     success     success                    1,7,16-17,4
        8,61,63,66,
        69,73-74,76
        ,78,80-82,8
        6,90,94,....
SW-A-SITE-NK5-02#
SW-A-SITE-NK5-02# sh vpc consistency-parameters global
    Legend:
QoS                         2     ([], [3], [], [], [],  ([], [3], [], [], [],
Network QoS (MTU)           2     (1538, 0, 0, 0, 0, 0)  (1538, 0, 0, 0, 0, 0)
Network Qos (Pause)         2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Input Queuing (Bandwidth)   2     (50, 50, 0, 0, 0, 0)   (50, 50, 0, 0, 0, 0)
Input Queuing (Absolute     2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
Output Queuing (Bandwidth)  2     (50, 50, 0, 0, 0, 0)   (50, 50, 0, 0, 0, 0)
Output Queuing (Absolute    2     (F, F, F, F, F, F)     (F, F, F, F, F, F)
Priority)
STP Mode                    1     Rapid-PVST             Rapid-PVST
STP Disabled                1     None                   None
STP MST Region Name         1     ""                     ""
STP MST Region Revision     1     0                      0
STP MST Region Instance to  1
VLAN Mapping
STP Loopguard               1     Disabled               Disabled
STP Bridge Assurance        1     Enabled                Enabled
STP Port Type, Edge         1     Normal, Disabled,      Normal, Disabled,
BPDUFilter, Edge BPDUGuard        Disabled               Disabled
STP MST Simulate PVST       1     Enabled                Enabled
VTP domain                  2     sysit-A-SITE           sysit-A-SITE
VTP version                 2     2                      2
VTP mode                    2     Transparent            Server
VTP password                2     system                 system
VTP pruning status          2     Disabled               Disabled
Allowed VLANs               -     1,7,16-17,48,61,63,66, 1,7,16-17,48,61,63,66,
                                  69,73-74,76,78,80-82,8 69,73-74,76,78,80-82,8
                                  6,90,94,96,150-151,160 6,90,94,96,150-151,160
                                  -161,200,203,210,300-3 -161,200,203,210,300-3
                                  07,400,403-410,412-413 07,400,403-410,412-413
                                  ,418-421,423-430,434,4 ,418-421,423-430,434,4
                                  37-443,445-451,460-462 37-443,445-451,460-462
                                  ,510,557-560,562-570,5 ,510,557-560,562-570,5
                                  76-583,666,700-707,709 76-583,666,700-707,709
                                  -717,851,853-856,999,3 -717,851,853-856,9....
Local suspended VLANs       -     -                      -
SW-A-SITE-NK5-01# sh vpc brief
Legend:
vPC domain id                   : 5
vPC role                        : primary
vPC status
        8,61,63,66,
        69,73-74,76
        ,78,80-82,8
        6,90,94,....
    Legend:
Priority)
Priority)
VLAN Mapping
VTP version                 2     2                      2
VTP mode                    2     Server                 Transparent
SW-A-SITE-NK5-01#
vucko-sanel Mon, 06/04/2012 - 06:27
anu ideas ?
SW-A-SITE-NK5-01# sh vtp status
VTP Status Information
VTP Version                     : 2 (capable)
Configuration Revision          : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs        : 126
VTP Operating Mode              : Server
VTP Domain Name                 : sysit-A-SITE
VTP Pruning Mode                : Disabled (Operationally Disabled)
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 Digest                      : 0x49 0x13 0x8A 0xAB 0xED 0x92 0xCB 0x4B
Configuration last modified by 0.0.0.0 at 0-0-00 00:00:00
Local updater ID is 0.0.0.0
VTP version running             : 1
SW-A-SITE-NK5-01#
SW-A-SITE-NK5-02# sh vtp status
Number of existing VLANs        : 122
VTP Operating Mode              : Transparent
MD5 Digest                      : 0x7B 0xCE 0x13 0x75 0x7A 0x2B 0x44 0x3C
SW-A-SITE-NK5-02#
The onlye reasone i am able to see here is that switch 2 does not have  those vlan og some reason whic actually should be there by default ?
1002 enet  CE
1003 enet  CE
1004 enet  CE
1005 enet  CE
vucko-sanel Mon, 06/04/2012 - 07:15
okay ..
i decided to remove feature vpc from both switches and let the switch1 be vtp server and switch 2 client (changed from transparent mode) and thing seems to work fine now ...i really dont why this did not worked ....
Ivan Shirshin Mon, 06/04/2012 - 10:55
Saw your update about QoS already after checking the config differencies and posting :-)
About VTP mismatch error - it is actually shown in the "sh vpc consistency-parameters global":
Looks like you got different VTP modes on your switches while those should be matching.
Kind Regards,
Ivan
vucko-sanel Mon, 06/04/2012 - 11:52
Ivan, what is the reason why my configuration cannot be like mentioned in attached files in my first post?
I am using two Nk5 switches and they are connected together like u can see from configuration files, by using 2x10 Gig interfaces and they are in one vPC domain and i am using peer keepalive between switches as well.
I want to use one of those Nk5 switches (swith 01) like a vtp server and all other switches in the network, including Nk5 switch 2, in transparent mode. But this scenario seems not to work properly...
glen.grant Mon, 06/04/2012 - 14:11
VPC and VTP have nothing in common  so it depends on how you want to connect your servers up .   VPC is used when you want redundant connections to 2 different switches in a active/active setup .
vucko-sanel Mon, 06/04/2012 - 14:20
Grant i do understand differences between vPC and VTP . My question is why i was not able to run VTP Transparent mode on switch-02 when the switch-01 were placed in VTP Server mode ..?
So evry time I want to add one new VLAN ID on switch-01, that new vlan id should appear on switch-02 as well...
after i changed VTP mode on switch-02 from Transparent to the Client mode, following error messages disappeared
Legend:
vPC domain id                   : 5
Type-2 consistency status       : success
vPC role                        : primary
Legend:
vPC domain id                   : 5
Ivan Shirshin Tue, 06/05/2012 - 10:23
If you have a chance, try to configure transparent mode again. In case it does not show the inconsistency, then you could have hit the following bug:
     CSCtn48439    Type-2 consistency failed for vtp after switchover
Kind Regards,
Ivan
Related Content
