Warning message
SRW224G4 - How send firmware?
I tried to upload the new firmware and unfortunately I turned off Swith too early. Now when I connect the serial port I did not want to end run the firmware.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.2 Built  17-Aug-2006  14:55:46
Linksys SmartSwitch based on 88E6218 with ARM946E-S.
32MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
FAIL !!! Check image for valid file.
Please download a new image.
Downloading code using XMODEM.
Download failed
Perform WARM BOOT ...
How to re-upload the firmware?
Yes! It.s work!
Thank you very much!
Kind Rwgards
- david.
Wiadomość napisana przez ishirshi w dniu 2012-06-04, o godz. 12:44:
Home
Re: SRW224G4 - How send firmware?
created by Ivan Shirshin in LAN, Switching and Routing - View the full discussion
Hi Dawid,
Please check this guide, page 64:
http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administratio...
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Reply to this message by going to Home
Start a new discussion in LAN, Switching and Routing at Home
Ivan Shirshin Tue, 06/05/2012 - 10:13
  • Cisco Employee,
Welcome, Dawid, glad that everything is fine now! Appreciate if you could mark the correct answer and rate useful posts :-)
Kind Regards,
Ivan
