INTER-AS-VPLS
Jun 4th, 2012
Dear ,
I’m trying to configure INTER-AS VPLS as the attached topology the ASBR1:Cisco IOS , PE1:ASR9K and ASBR2:Juniper MX
The L2vpn BGP Multi-hope BGP is up and I can see the label swapping form the both end but the VC is down
RP/0/RSP0/CPU0:IGW-LON-1#show l2vpn bridge-domain neighbor 192.168.255.3 detail
Mon Jun  4 10:17:14.691 UTC
Bridge group: MPLSl2VPN, bridge-domain: MPLSL2VPN, id: 0, state: up, ShgId: 0, MSTi: 0
  MAC learning: enabled
  MAC withdraw: enabled
    MAC withdraw for Access PW: enabled
  Flooding:
    Broadcast & Multicast: enabled
    Unknown unicast: enabled
  MAC aging time: 300 s, Type: inactivity
  MAC limit: 4000, Action: none, Notification: syslog
  MAC limit reached: no
  MAC port down flush: enabled
  MAC Secure: disabled, Logging: disabled
  Split Horizon Group: none
  Dynamic ARP Inspection: disabled, Logging: disabled
  IP Source Guard: disabled, Logging: disabled
  DHCPv4 snooping: disabled
  IGMP Snooping profile: none
  Bridge MTU: 1500
  MIB cvplsConfigIndex: 1
  Filter MAC addresses:
  Create time: 04/06/2012 08:00:37 (02:16:36 ago)
  No status change since creation
  ACs: 1 (1 up), VFIs: 1, PWs: 1 (0 up), PBBs: 0 (0 up)
  List of Access PWs:
  List of VFIs:
    VFI L2VPN
      VPN-ID: 2, Auto Discovery: BGP, state is Provisioned (Service Connected)
      Route Distinguisher:  65500:800
      Import Route Targets:
        65500:800
      Export Route Targets:
        65500:800
      Signaling protocol: BGP
      Local VE-ID: 2 ,  Advertised Local VE-ID : 2
      VE-Range: 10
      PW: neighbor 192.168.255.3, PW ID 2, state is down ( all ready ) (Transport LSP Down)
        PW class not set, XC ID 0xfffc0002
        Encapsulation MPLS, Auto-discovered (BGP), protocol BGP
        PW type VPLS, control word disabled, interworking none
        PW backup disable delay 0 sec
        Sequencing not set
          MPLS         Local                          Remote
          Label        16015                          262210
          MTU          1500                           unknown
          Control word disabled                       disabled
          PW type      VPLS                           VPLS
          VE-ID        2                              1
        MIB cpwVcIndex: 4294705154
        Create time: 04/06/2012 08:40:51 (01:36:22 ago)
        Last time status changed: 04/06/2012 08:40:51 (01:36:22 ago)
        MAC withdraw message: send 0 receive 0
        Static MAC addresses:
      VFI Statistics:
        drops: illegal VLAN 0, illegal length 0
Mon Jun  4 10:18:25.316 UTC
BGP router identifier 192.168.106.201, local AS number 65555
BGP generic scan interval 60 secs
BGP table state: Active
Table ID: 0x0   RD version: 3889240856
BGP main routing table version 13
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
              i - internal, r RIB-failure, S stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network            Next Hop        Rcvd Label      Local Label
Route Distinguisher: 65500:800 (default for vrf MPLSl2VPN:MPLSL2VPN)
*> 1:1/32             192.168.255.3   262209          nolabel
*> 2:1/32             0.0.0.0         nolabel         16015
belalcciejo Sun, 06/10/2012 - 06:02
Hi ,
I will share my experience in this
Due to my requirements to have Mnulti-hope L2 vpn signaling between ASBR2 and PE1 I used this RFC option C   http://tools.ietf.org/html/rfc4761#section-3.4
ASBR1: Junos MX
ASBR2:Cisco 7600( you can’t run VPLS BGP signaling on this router you need extra card ES+ because of this I used method C )
PE1:ASR9K
The configuration as below
  • •1-      As100 running LDP and AS200 running RSVP
  • •2-      Send the label unicast using BGP between ASBR1&ASBR2 and advertise the Loopback ip addresses of PE1,ASBR1 & ASBR2 between each other using BGP
From cisco : neighbor ASBR2 address send-label
From Juniper side :
type external;
family inet {
   labeled-unicast {
       resolve-vpn;  // you need to insert this command to make the LSP up inside inet.3 table
neighbor ASBR1 address
  • •3-      Inside ASBR1 you need to redistribute the ASBR2 inside the IGP
  • •4-      Multi-hope L2vpn signaling between the PE1 & ASBR2
type external;
multihop;
local-address 192.168.255.3;
family l2vpn {
   signaling;
neighbor  PE1 loopback Ip
form ASR:
af-group L2VPN address-family l2vpn vpls-vpws
route-policy pass-all in
route-policy pass-all out
session-group L2VPN
remote-as 65500
ebgp-multihop 255
update-source Loopback200
neighbor-group L2VPN
use session-group L2VPN
   use af-group L2VPN
neighbor ASBR2 loopback IP
use neighbor-group L2VPN
  • •5-      VPLS configuration :
Form Juniper:
show routing-instances MPLSL2VPN-INTER-AS
instance-type vpls;
interface ge-11/0/1.70;
route-distinguisher 200:800;
vrf-target target:200:800;
protocols {
   vpls {
       traceoptions {
           file MPLSL2.log;
           flag all;
       site-range 10;
       mac-table-size {
           16;
       interface-mac-limit {
           8;
       no-tunnel-services;
       site 1 {
           site-identifier 1;
Form ASR side :
l2vpn
autodiscovery bgp
signaling-protocol bgp
   mtu mismatch ignore //// you need this command very very necessary as without this the PW will not become UP
bridge group MPLSL2VPN-INTER-AS
bridge-domain MPLSL2VPN-INTER-AS
   interface GigabitEthernet0/0/0/0
   vfi L2VPN
   vpn-id 2
   autodiscovery bgp
     rd 200:800
     route-target 200:800
     ve-id 2
Eric Guo Tue, 01/21/2014 - 08:35
hi Friend,
could you possible to send me one completely configuration file ? many thanks!
Eric
