Many-to-one NAT on L2L VPN (ASA 5505)
Jun 4th, 2012
I am trying to confgure a L2L VPN tunnel to a service provider using an ASA 5505.
My problem is that the service provider will not accept traffic from a LAN subnet, they will only accept traffice from a public IP.
We have a small public subnet of x.x.x.50/255.255.255.248, our public IP (outside interface IP on the ASA 5505) is x.x.x.50 and the service provider wants to see traffic coming from us on x.x.x.51
How can I NAT our LAN subnet (10.0.0.0/24) to one public IP (x.x.x.51)?
Im new to Cisco firewalls so essentially I need a complete config
All help is highly appreciated
Julio Carvajal Mon, 06/04/2012 - 15:27
Hello Cato,
For that NAT you need the following:
192.168.12.0/24 Is the ISP network
10.0.0.0 /24 is the Inside local network
access-list test permit ip 10.0.0.0 255.255.255.0 192.168.12.0 255.255.255.0
nat (inside) 10 access-list test
global (outside) 10 x.x.x.51
On the encryption VPN traffic (Crypto ACL)
the encrypted traffic will be from:
     access-list VPn permit ip host x.x.x.51 192.168.12.0 255.255.255.0
Julio
Rate all the helpful posts
NPBergen08 Mon, 06/04/2012 - 15:54
Thank you for your answer, I did the suggested configuration but the tunnel will still not connect.
Regarding the L2L VPN setup, should the local network be x.x.x.51 or the local LAN subnet (10.0.0.0/24)?
Best regards,
Cato
Julio Carvajal Mon, 06/04/2012 - 16:00
Hello Cato,
The local subnet will be 10.0.0.0/24 but for the ISP will look like x.x.x,51
Please post entire config for assistance,.
NPBergen08 Mon, 06/04/2012 - 16:16
Thats how it is configured. Im trying to find traces of VPN connection attempts in the log but cant find any?
Best regards,
Cato
Julio Carvajal Mon, 06/04/2012 - 16:20
It could be a problem on the ISP side.
Again please post the configuration for assistance.
NPBergen08 Mon, 06/04/2012 - 23:29
Here is the running config:
ASA Version 8.2(5)
hostname ciscoasa
enable password ########## encrypted
passwd ######### encrypted
names
name x.x.170.0 FirstDataLAN
name 85.252.49.19 FastWEB
name 10.0.0.1 GW
name 10.0.0.97 PC_Espen
name x.x.x.50 ASA-peer
name x.x.171.161 FDL-VPN-peer
name 195.160.170.79 FDl_service-ip
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address GW 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address ASA-peer 255.255.255.248
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service MS_SQL
service-object tcp eq 1433
service-object tcp eq sqlnet
object-group network FDL_VPN
network-object 10.0.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0
access-list outside_access_in remark test
access-list outside_access_in extended permit ip host FDL-VPN-peer host ASA-peer log
access-list outside_access_in extended permit ip x.x.x.48 255.255.255.248 FirstDataLAN 255.255.255.0 log
access-list outside_access_in extended permit ip host ASA-peer host FDL-VPN-peer log
access-list outside_access_in extended permit ip FirstDataLAN 255.255.255.0 x.x.x.48 255.255.255.248 log
access-list outside_access_in extended permit object-group MS_SQL host FastWEB host 10.0.0.102
access-list outside_access_in extended permit object-group MS_SQL host FastWEB interface outside
access-list VPN extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0
access-list VPN extended permit ip host x.x.x.51 FirstDataLAN 255.255.255.0
access-list inside_access_in extended permit ip any any log
access-list inside_access_in extended permit tcp any any
access-list inside_access_in remark test
access-list inside_access_in extended permit ip x.x.x.48 255.255.255.248 FirstDataLAN 255.255.255.0 log
access-list inside_cryptomap_1 extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0
pager lines 24
logging enable
logging console informational
logging trap informational
logging asdm informational
logging facility 16
logging host inside PC_Espen
mtu inside 1500
mtu outside 1300
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (inside) 3 interface
global (outside) 2 interface
global (outside) 1 x.x.x.51 netmask 255.0.0.0
nat (inside) 10 access-list VPN
nat (inside) 2 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 1433 10.0.0.102 1433 netmask 255.255.255.255
static (outside,inside) tcp 10.0.0.102 1433 FastWEB 1433 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.49 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set FDL esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 4608000
crypto map inside_map 1 match address inside_cryptomap_1
crypto map inside_map 1 set pfs
crypto map inside_map 1 set peer FDL-VPN-peer
crypto map inside_map 1 set transform-set FDL
crypto map inside_map interface inside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 10.0.0.50-10.0.0.200 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
vpn-idle-timeout none
vpn-tunnel-protocol l2tp-ipsec webvpn
group-policy FDL internal
group-policy FDL attributes
vpn-filter value VPN
vpn-tunnel-protocol IPSec l2tp-ipsec
username user1 password nIsrUp5YwmRLVu/4 encrypted privilege 15
tunnel-group DefaultL2LGroup ipsec-attributes
isakmp keepalive threshold 15 retry 2
tunnel-group DefaultRAGroup ipsec-attributes
tunnel-group DefaultWEBVPNGroup ipsec-attributes
tunnel-group x.x.171.161 type ipsec-l2l
tunnel-group x.x.171.161 general-attributes
default-group-policy FDL
tunnel-group x.x.171.161 ipsec-attributes
pre-shared-key *****
isakmp keepalive threshold 15 retry 10
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:b4cb57a31f3c3ee66438e30af7686439
: end
Best regards,
Cato
Julio Carvajal Tue, 06/05/2012 - 05:07
Hello Cato,
Here is what I want you to change as its not properly setup:
no access-list VPN extended permit ip host x.x.x.51 FirstDataLAN 255.255.255.0
no access-list inside_cryptomap_1 extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0
access-list inside_cryptomap_1 extended permit ip host  x.x.x.51FirstDataLAN 255.255.255.0
Julio
NPBergen08 Tue, 06/05/2012 - 09:21
I (think) I managed to make the suggested changes but the tunnel still wont establish connection.
I did a show crypto isakmp and got this output:
There are no isakmp sas
Global IKE Statistics
Active Tunnels: 0
Previous Tunnels: 1
In Octets: 2880
In Packets: 10
In Drop Packets: 0
In Notifys: 0
In P2 Exchanges: 0
In P2 Exchange Invalids: 0
In P2 Exchange Rejects: 0
In P2 Sa Delete Requests: 0
Out Octets: 3968
Out Packets: 25
Out Drop Packets: 0
Out Notifys: 0
Out P2 Exchanges: 7
Out P2 Exchange Invalids: 0
Out P2 Exchange Rejects: 0
Out P2 Sa Delete Requests: 7
Initiator Tunnels: 1
Initiator Fails: 0
Responder Fails: 0
System Capacity Fails: 0
Auth Fails: 0
Decrypt Fails: 0
Hash Valid Fails: 0
No Sa Fails: 0
Global IPSec over TCP Statistics
Embryonic connections: 0
Active connections: 0
Previous connections: 0
Inbound packets: 0
Inbound dropped packets: 0
Outbound packets: 0
Outbound dropped packets: 0
RST packets: 0
Recevied ACK heart-beat packets: 0
Bad headers: 0
Bad trailers: 0
Timer failures: 0
Checksum errors: 0
Internal errors: 0
This is the policy requirements from the service provider:
Isakmp policy:
Encryption algorithm:                    AES256
Hash algorithm:                               SHA
Authentication method:                    Pre-Shared Key
Diffie-Hellman group:                     #5 (1536 bit)
Lifetime:                                        1440 min
Aggressive mode:                              None
Ipsec policy:
Hash algorithm:                               SHA
Security association lifetime:          3600 seconds
Perfect forward secrecy:                    Group 2
As far as I can tell the tunnel should be configured according to these requirements?
This is the currently running config:
ASA Version 8.2(5)
hostname ciscoasa
enable password ####### encrypted
passwd ###### encrypted
names
name 10.0.0.1 GW
name x.x.170.79 FDl_service-ip
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list outside_access_in extended permit ip 84.49.73.48 255.255.255.248 FirstDataLAN 255.255.255.0 log
access-list outside_access_in extended permit ip FirstDataLAN 255.255.255.0 84.49.73.48 255.255.255.248 log
access-list inside_cryptomap_1 extended permit ip host x.x.x.51 FirstDataLAN 255.255.255.0
access-list inside_access_in extended permit ip 84.49.73.48 255.255.255.248 FirstDataLAN 255.255.255.0 log
access-list inside_cryptomap_2 extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0
pager lines 24
logging enable
logging facility 16
mtu inside 1500
mtu outside 1300
arp timeout 14400
http server enable
crypto map inside_map 1 match address inside_cryptomap_2
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 2
encryption 3des
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
vpn-filter value inside_cryptomap_1
Cryptochecksum:403e2d4f17c5304ff1d9bd8252cb1886
: end
Best regards,
Cato
Julio Carvajal Tue, 06/05/2012 - 09:29
Hello Cato,
You are missing the global command for the NAT
Julio
NPBergen08 Tue, 06/05/2012 - 09:40
I tried that but got this response:
"global for this range already exists"
Best regards,
Cato
NPBergen08 Tue, 06/05/2012 - 10:00
Thank you, that made me able to make the config change but unfortunately the tunnel is still dead
Best regards,
Cato
Julio Carvajal Tue, 06/05/2012 - 10:05
The configuration looks fine,
Please check the ciphers you are using for phase one and phase 2 with the ISP so you can ensure they match.
NPBergen08 Tue, 06/05/2012 - 10:35
OK I will do that, and thank you for all your help, its highly appreciated.
Could I be so bold to ask if you could have a last look at the current config? I just want to be sure that I havent made a mistake with the last changes. What I did notice is that x.x.x.51 now seems to be x.x.x.48, which is our public network address?
ASA Version 8.2(5)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 10.0.0.1 GW
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
access-list inside_cryptomap_2 extended permit ip 10.0.0.0 255.255.255.0 FirstDataLAN 255.255.255.0 inactive
pager lines 24
logging enable
logging facility 16
mtu inside 1500
mtu outside 1300
arp timeout 14400
http server enable
encryption aes-256
hash sha
group 5
lifetime 86400
encryption 3des
hash sha
group 5
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
Cryptochecksum:03694ab933eb8d601d677fcf0afe7e8f
: end
Best regards,
Cato
Related Content
