VCS slow response in GUI after X7.1 upgrade
Answered Question
Jun 5th, 2012
We recentlty upgraded our VCS to X7.1 and are seeing the GUI response to be very slow.
We have the box integrated with LDAP for admin user authentication. We tried using the box with both Local and Remote authentication.
But still the login time takes around 3 minutes.
What should we check here to proceed further on this. Pls suggest.
Restart option will be the last resort.
Correct Answer by Haydn von Imhof about 4 years 10 months ago
I had the same issue with one of my VCS Expressways after implementing LDAP authentication on 7.1.
I have 6 VCS Controls and 4 Expressways all on the same software release and LDAP integration in the same video enviroment and just the one box was not happy.
Cisco suggested I try factory reset the box and reconfigure it but that did not help.
I ended up getting an RMA done.
Overall Rating: 5 (1 ratings)
Correct Answer
Haydn von Imhof Tue, 06/05/2012 - 05:50
Tomonori Taniguchi Tue, 06/05/2012 - 05:51
  • Cisco Employee,
Do you see any alarm on VCS?
You may check alarm from Web GUI (look for right top corner) or ssh to VCS and login as root user (after you successfully login as root user, all alarm will print out on your ssh session).
RAMEEZ RAHIM Tue, 06/05/2012 - 05:58
I could see no alarms relating to this..
The alarm is just for TMS agent legacy mode..
Haydn von Imhof Tue, 06/05/2012 - 06:08
I also tried loading a snapshot of my slow VCS to another test VCS unit and the test unit worked great.
When Cisco suggested I conduct a factory reset they wanted to see if there was something in the system config that caused the slow response.
But even just after the factory reset and having a blank VCS if look 2-3min to log in.
- Andreas
Edit: In comment to Haydn's reply, whatever the issue might be, it is more than likely an issue in software rather than hardware, meaning an RMA is most likely not needed to resolve the issue.
I agree.
My VCS was a critical production system so I could not wait for a lengthy investigation.
I am interested to see what comes out of this thread.
I will be returning my expressway this week and cisco will provide feedback so I will relay that on once I have it.
awinter2 Tue, 06/05/2012 - 05:50
  • Silver, 250 points or more
Hi Rameez,
is it only the actual login process which is slow, or also when you are browsing the various VCS pages once logged in?
I would in any case recommend you open a case with TAC and provide a full system snapshot from the VCS to help with further analysis.
- Andreas
RAMEEZ RAHIM Tue, 06/05/2012 - 06:02
It is only the initial login that takes time.
It goes normal after login..
awinter2 Tue, 06/05/2012 - 06:09
Does the login process also take a long time when you are using local authentication for admin users?
Could you try removing all of the LDAP configuration for user authentication, set admin login source to local and check if the issue persists?
RAMEEZ RAHIM Tue, 06/05/2012 - 06:35
We tried changing authentication source to Local, should we also try removing all LDAP coanfigurtion.
Also this issue is not happening
