Warning message
Unity Backups Created multiple times
Jun 5th, 2012
Hey guys!
Just wondering if anyone has run into an issue of their Unity backups being performed 2-3 times when it was only scheduled once.
So if it is scheduled to backup at 6:05AM it will run successfully three times at 6:05, 6:10 and 6:12. There are not warnings in the backup history. Any help would be awesome. Thanks!
Overall Rating: 5 (1 ratings)
Rob Huffman Wed, 06/06/2012 - 05:40
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Craig,
Can you please clarify if this is Unity or Unity Connection and the exact version
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
craig.phillips@... Wed, 06/06/2012 - 09:40
Hey Rob!
We are running Unity Connection
Version 7.1.2.20000-140
Ever heard of this issue before?
Rob Huffman Wed, 06/06/2012 - 09:51
  • Hall of Fame,
    Founding Member
Hi Craig,
Do you have multiple Message Stores configured? If so, I blieve this is working as designed
Cheers!
Rob
Rob Huffman Thu, 06/07/2012 - 07:17
  • Hall of Fame,
    Founding Member
Hi Craig,
Yeah...that's very weird!
It looks like it's gone to 3 per night now I've looked for bugs that might explain this
behavior and have come up empty.
I would really try to move this to a TAC case at this point. We really had some crazy things happen
when we were running 7.1(2) it was a very buggy build. You might want to look at upgrading to
7.1(3b)su2 as it has been an extremely solid build.
Sorry man! You could also try a re-boot as a first step as well.
Cheers!
Rob
Christian Chautems Thu, 07/05/2012 - 07:04
Funny today I have found one of my customer cluster doing the same but with CUCM 7.1.5.31900-3
I have restarted the DRF Master after looking in the logs without finding anything. I will update later
Since I am going to holidays and it is not critical I will check on my return.
Christian
Screenshot below:
craig.phillips@... Thu, 07/05/2012 - 09:11
Hey just an update on my case for future reference. All I had to do was restart the DRF Master service and everything is functioning as it should. Thanks!
Rob Huffman Thu, 07/05/2012 - 12:14
  • Hall of Fame,
    Founding Member
Hey Craig,
Thanks for posting back with your results here! +5 for this very
kind gesture
Cheers!
Rob
Related Content
