Warning message
Should we simply not consider WCS?
Jun 5th, 2012
We are starting an Wireless infrastructure project and up until yesterday, WCS plus was the way we were going. Now I have been reading about NCS and Prime. What are the facts concerning WCS and which product is going to be the flagship into the next 3-5 years?
fbarboza Wed, 06/06/2012 - 10:28
  • Bronze, 100 points or more
If you have WLCs like the 2100 or 4400 they go up to code 7.0 so you will need a WCS to manage them, but if you have WLCs that support code 7.2 or higher like the 5500 or 2500 then you will need a NCS to manage them.
Saravanan Lakshmanan Tue, 06/05/2012 - 23:49
  • Cisco Employee,
NCS support WLCs that run code from 4.2 to 7.2 and WCS support ends at WLC running 7.0.
Almost, all non EOL WLCs supported on code 7.0 i.e, legacy & new WLC platform that can be managed using WCS or NCS. If you prefer to update the WLC platform that supports 7.2 i.e, 2500, 7500, 5500 & Wism2 then those WLCs can't be managed by WCS. And future WLC that will be released also can only be managed with NCS.
Software Release Compatibility Matrix:-
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp41742
End-of-Sale and End-of-Life Announcement for the Cisco Wireless Control System Legacy Licenses
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/end_of_life_c51-556750.html
David Santos Fri, 06/08/2012 - 15:41
Simple!
NCS is the way because you are expecting to use the new code versions.
And be aware that the last app support will be in February 28, 2013
PS: I migrated from WCS to NCS and got NO problem till this day.
jino_jacob Wed, 10/10/2012 - 09:18
Does it mean NCS does not support the 2100 or 4400 WLCs?
Related Content
