SSH NOT WORKING
Jun 5th, 2012
Hello ,
            I have an switch 2960 and i have made an SSH connection . But the problem is that whenever i try to open with my teraterm or putty it ask for username and after that password but does take the password. It shows an error of password what should be the problem.
Commands that i entered to make SSH
config# username admin password pankaj
config# ip domain-name home.local
config# crypto key generate rsa
config# 1024
config# ip ssh version 2
Peter Paluch Tue, 06/12/2012 - 01:02
  • Cisco Employee,
Two questions:
  1. In the line vty 0 15 section of the configuration, did you configure the login local command?
  2. Have you created any usernames using the username LOGIN secret SECRET in the configuration?
Best regards,
Peter
Related Content
