Warning message
IP Phone support 6921 on 7.1.2.20000-2
Jun 5th, 2012
I want to have the 6921 installed on the cucm 7.1.2.20000-2, but it is not supported in this callmanager version, can I upgrade the devices with the "cmterm-devicepack7.1.5.35099-1.cop.sgn" file or need I to use another file to have support of the 6921 on the 7.1.2 ?
Gordon Ross Tue, 06/05/2012 - 23:13
  • Blue, 1500 points or more
That devicepack is only for 7.1.3, not the 7.1.2. you say you're on.
There is a devicepack for 7.1.2, though: 7.1.2 (22010-1)
The readme says it includes firmware for the 69xx series phones.
GTG
pbogaerts Mon, 06/11/2012 - 10:48
Previous is very helpfull, but is it possible just to add the 6921 by adding the device with the cmterm-6921_6941_6961-sccp.8-5-3-0.cop.sgn file
Now we have 7941 connected and we want to add only the 6921,
Thanks.
Gordon Ross Mon, 06/11/2012 - 15:10
Devicepacks add all the necessary database information to support new types of phone. If the 6921 isn't listed in Device->Phone->Add New, then you *have* to install the devicepack (and reboot all the nodes in the cluster)
GTG
nikshah Tue, 06/12/2012 - 02:00
  • Cisco Employee,
For the new device to show up you would need to install the dev pack ...as Gordon mentioned.
pbogaerts Tue, 06/12/2012 - 10:55
ok I will install the device package 7.1.2.220010, I thought that it would work with the
6921_6941_6961-sccp.8-5-3-0.cop.sgn file and this would be faster +/-2MB against for the device package 215MB
